will f22a1 head bolt up to sohc f22b1 block?
hey guys I was wondering if a f22a1 head will bolt up to a 94 accord f22b1 block with no modifications and also is this block still 8.8 compression with iron sleeves ? Thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superjunprelude »</TD></TR><TR><TD CLASS="quote">Bump come on guys help? Pirate? </TD></TR></TABLE>
im no pirate, but the f22a1 head will bolt up just fine, no mods nessesary. same head studs will work also. A h23 head would work just as well too.
since when did pirate become the resident guru
edit: don't forget to put in place the oil control oriface since you won't be using a vtec head anymore!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">im no pirate, but the f22a1 head will bolt up just fine, no mods nessesary. same head studs will work also. A h23 head would work just as well too.
edit: don't forget to put in place the oil control oriface since you won't be using a vtec head anymore!</TD></TR></TABLE>
thanks alot man yea i might do the h23 heead well see
One more question so I'm usins the f22a1 one head on the f22b2 block do I use a f22a1 headgasket or f22b2 head gasket ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">since when did pirate become the resident guru
I am not a guru. I have done 1.5 hybrid engines. Hardly a lot. I am just good at being a jerk. People remember jerks better. :D
Pirate
Pirate
I am gonna guess you are gonna want to use the gasket for the A1 head. Seems to be the most likely choice to me.
Not 100% certain on that though, more like 80% certain!
Guest
Posts: n/a
I am tellin ya man try and find yourself an H23 head. This is the same build I am gonna be doing very soon. The H23a head is 100x better than the F22a1 head. Larger Intake manifold, larger throttle body, DOHC. And it is practically a direct bolt on. It don't get much easier.
willard steen
Apr 5, 2016 12:22 AM
hybridpatient95
May 9, 2006 10:43 AM
