Shifter rattle? (searched) (all stock parts)
Old Sep 1, 2006 | 02:45 PM
Fishy's Avatar
Default Shifter rattle? (searched) (all stock parts)
97 LX 5spd. bone stock except for an axle-back grapefruit shooter with the silencer permanently installed. Also all of the search results I saw had to do with short shifters or exhaust interference so here's my question:
When cruising at light to medium throttle in 3rd or 5th gear I get a stupid rattle in my shifter assembly. Whilst under the car the other day I inspected my shift linkage and I think I know where the problem is but I'm not sure how to fix it. I traced the rattle to one of the two joints right behind to the legendary 'bitch pin'. The joint has a grease fitting on it but I didn't have a grease gun with me to try that as a solution. So I ask you folks, the gurus, what can be done about this issue? Is it just a matter of the joint being dry of grease or can these joints be serviced with bushings or the like?
thanks in advance!
CHANCELLOR12
Transmission & Drivetrain
Nov 1, 2016 10:08 PM
jdm_j03
19
Jun 30, 2008 04:36 PM
danteisme
Oct 6, 2005 02:57 AM
EG-lowrider
Jan 8, 2004 02:31 PM
DI9ITAL
Feb 8, 2003 09:09 PM
