Suspension & Brakes Theory, alignment, spring rates....
GC/koni question, most travel
Old Sep 1, 2006 | 02:17 PM
mtny's Avatar
Default GC/koni question, most travel
When I install my Ground Controls with my Koni Yellows, should I adjust the GC's or just drop the perch on my shocks? I am riding on H & R Race springs/Koni Yellows and I have no travel in my shocks. I have a horrible ricey bounce. I hope the GC's will eliminate it. Thanks
Old Sep 1, 2006 | 03:09 PM
Dartanian's Avatar
Default Re: GC/koni question, most travel (mtny)
If you are bouncing, turn up rebound on the shocks.
Adjusting the coilovers is a lot easier than removing the whole shock assembly to drop the perches.
Old Sep 1, 2006 | 03:19 PM
mtny's Avatar
Default Re: GC/koni question, most travel (Sleeper Style)
Well I have to remove the whole shock anyway so...
Old Sep 1, 2006 | 05:57 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny &raquo;</TD></TR><TR><TD CLASS="quote">Well I have to remove the whole shock anyway so... </TD></TR></TABLE>
As long as the threaded sleeve doesn't sit higher than the top ofthe shock, it doesn't really matter what perch you set the Konis at, since you'll adjust height with the GC sleeve. I left mine on the normal positions.
Old Sep 1, 2006 | 06:27 PM
Tad's Avatar
Tad
how long are your bumpstops?
maybe you need to cut em?
Old Sep 1, 2006 | 06:31 PM
mtny's Avatar
Default Re: (Tad)
OEM Bump stops.
Old Sep 1, 2006 | 06:40 PM
Tad's Avatar
Tad
Default Re: (mtny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny &raquo;</TD></TR><TR><TD CLASS="quote">OEM Bump stops. </TD></TR></TABLE>
are they cut?
Old Sep 1, 2006 | 06:53 PM
mtny's Avatar
Default Re: (Tad)
No. Are you saying I need to cut them if so, what exactly do you mean (as in where to cut)?
Old Sep 1, 2006 | 06:58 PM
Tad's Avatar
Tad
yep,
that's your problem right there.
oem bumpstops are way too long for a lowered car.
basically they're stealing all ur suspension travel.
just take them off, and cut them in half.
Personally i cut mine down to 1/3 of their normal size, but I actually have more travel than I need now.
so yeah, cut them in half should do it.
reinstall the bottom(thicker) half, on your shocks.
it'll give you over an inch more travel,
which means much more an an inch at the tire!
Old Sep 1, 2006 | 07:34 PM
mtny's Avatar
Default Re: (Tad)
What did you use to cut it? I have limited resources. Thanks alot for your help.
Old Sep 1, 2006 | 09:48 PM
Dartanian's Avatar
Default Re: (mtny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny &raquo;</TD></TR><TR><TD CLASS="quote">What did you use to cut it? I have limited resources. Thanks alot for your help. </TD></TR></TABLE>
A hack saw or pair of scissors. It is just foam.
Old Sep 2, 2006 | 01:10 AM
Tad's Avatar
Tad
Default Re: (mtny)
razor blade dude,
you've got to take your shock/spring assembly off and apart,
then just cut it.
it is a tough material though,
sleeper styles hacksaw idea would be a good one. Would probably cut thru it like butter.
Old Sep 2, 2006 | 06:05 PM
Dartanian's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">
sleeper styles hacksaw idea would be a good one. Would probably cut thru it like butter.</TD></TR></TABLE>
Oh, it did.
lowlight
Suspension & Brakes
Jul 8, 2005 03:25 PM
Unjockable
Feb 21, 2005 08:07 PM
fishnfst
Dec 8, 2003 06:37 PM
DR.DRum
Apr 24, 2003 06:45 PM
96 SOHC VTEC
24
Jan 27, 2002 07:56 PM
