Please help me brothers, ITR problem
Old Sep 1, 2006 | 12:06 AM
deadman-ITR's Avatar
Default Please help me brothers, ITR problem
https://honda-tech.com/zerothread/1738803
Old Sep 1, 2006 | 02:15 AM
Speed Infliction's Avatar
Default Re: Please help me brothers, ITR problem (deadman-ITR)
i know for sure that a better header would benefit your motor a lot. don't know if that is the problem though. maybe you feul pump.
Old Sep 1, 2006 | 04:47 AM
BoBo Racing's Avatar
Default Re: Please help me brothers, ITR problem (Speed Infliction)
i beleive its the cams buddy club cams are known for making great mid range not for top end they ususally die out around 8000-8500 rpms ur motor is probably maxed out if it was tuned properly, and if anything do a compression test also.
Old Sep 1, 2006 | 04:56 AM
RTW DC2R's Avatar
Im not familiar with the BC 4 cams, but in comparison to my old JUN3 setup, which was good for top end peak power, I can tell you this(assuming your motor is running properly and has no problems). Your torque is definitely going to fall off, but your HP shouldnt fall as much on these motors.
what is an "ITR Receiver and custom intake"? If by this you mean the stock ITR airbox, I would suggest something else as that is probably restricting your top end. On my old JUN3 setup, I put my stock intake back on for the hell of it one day and the car felt like it fell on its face, which appears to be the case with your car as well. I do not have any dyno comparison to prove it though so take it for what its worth.
A better header may help some as well. Otherwise I dont see much problem with the setup, except I would ditch the MSD ignition as the stock ignition is sufficient. Maybe it just needs more tuning time as well.
Old Sep 1, 2006 | 06:06 AM
Default Re: (RTW DC2R)
my motor is running properly and has no problems
sorry, i've mean ITR stock intake manifold My air box is not stock, its hand made on the 70-80mm pipe with Green Twister filter.
Ok, i'll try Toda ITB on the next week
Old Sep 1, 2006 | 11:46 AM
Default Re: (deadman-ITR)
you will be surprised how much more horespower you will get off of a better header. the header is your most important bolt on and will yeild the most HP.
Old Sep 1, 2006 | 12:35 PM
Default Re: (Speed Infliction)
will see
any other ideas ?
Old Sep 10, 2006 | 11:44 AM
well i've the Toda ITB. Dyno results is shitty
204 HP and 190.9TQ
what the fck
Old Sep 10, 2006 | 12:26 PM
LunchboxZT's Avatar
All that Power and pushing the Motor all the way to 9,000 RPM and you're still running an OEM ITR Header? You're power is probably falling off due to the exhaust gases not having anywhere to go, trust me, try looking for something with better flow - Or at the very least get the header polished out.. seems odd to me you'd get the entire Type-R head ported and polished and leave out the header.
As stated before, it's probably the most important bolt on.
Old Sep 10, 2006 | 08:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadman-ITR &raquo;</TD></TR><TR><TD CLASS="quote">well i've the Toda ITB. Dyno results is shitty
204 HP and 190.9TQ
what the fck </TD></TR></TABLE>
header!!!!!!!!!!
Old Sep 11, 2006 | 01:37 AM
yeah, i think you absolutly right...
ACrite3404
Mar 25, 2008 04:29 PM
9civichatch3
12
Sep 6, 2007 06:03 PM
Only1cam
25
Nov 11, 2006 01:07 PM
turbohf
45
Jul 28, 2006 09:22 PM
SpoolnEG6
Apr 29, 2006 05:05 AM
