Turn signals no worky
Old Aug 31, 2006 | 06:32 PM
RemoveGiantWingOnYourCar's Avatar
Default Turn signals no worky
89 SI
nothing happens when i use the turn signal, is it a relay, bulb?
i checked the fuse and it was fine
Old Aug 31, 2006 | 06:34 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: Turn signals no worky (RemoveGiantWingOnYourCar)
both of them dont work? check for shorts, check relay, check bulbs, check switches. Do the hazards work?
Old Aug 31, 2006 | 06:37 PM
Default Re: Turn signals no worky (AnthonyG2003)
neither of them work
i looked at the bulbs and the filaments look good, is there an easy way to test them?
not sure on the hazards, i don't think they work
Old Aug 31, 2006 | 07:08 PM
M2B4's Avatar
yeah lol pull the bulb out and shake it if nothing is loose when you shake it grab a multimeter and test the wires.
Old Sep 1, 2006 | 08:27 AM
Default Re: Turn signals no worky (M2B4)
i'm giving away my complete lack of expertise, but i will try that with the multimeter, maybe it is just a bulb, i guess after 197,000 miles a bulb could burn out
Old Sep 1, 2006 | 09:45 AM
AndyD's Avatar
My initial thought since both aren't working is the turnsignal switch. The arm you push up and down to turn the signals on.
I would first try checking the voltage going to the bulb sockets though.
Old Sep 2, 2006 | 05:32 AM
Default Re: Turn signals no worky (AndyD)
thanks for the help, it turns out the bulbs were fine but the 15 amp hazards fuse (under the hood) blew, so i replaced it with a spare one from under the dash and now they work fine, since the car is so old i'm not going to worry about why the fuse blew
Old Nov 2, 2006 | 06:13 PM
Well, replacing the fuse worked for exactly 2 months, the fuse burned out again so I put a new one in and it burned out as soon as I hit the turn signal. I tried one more time just to be sure and the same thing happened.
How do you check for a short?
Or what else could be the problem
si90rex
Aug 10, 2006 09:54 AM
trrbl1bmx
14
Jul 10, 2006 07:50 PM
jdm_junkie
Aug 12, 2004 06:09 PM
SpoonFedHatch
Jul 11, 2004 09:40 PM
mike5809
Dec 17, 2003 05:16 PM
