b16 compression test
Old Aug 31, 2006 | 03:39 PM
Heretic:Si's Avatar
Default b16 compression test
i just did a compression test on my b16a2 for the hell of it, 85,000 miles runs perfect and has never burned a drop of oil. i have a catch can on the pcv valve and i get like a teaspoon in a month.
#1=210
#2=210
#3=210
#4=180
i know these numbers are all ok. i'm wondering about the difference between #4 and the rest of them. i put some oil in the cylinder and it stayed the same, so i'm assuming it's in the head. so any opinions on what it might be and if i should even worry about it? i'm saving for a k series, but that isn't going to happen for a couple years.
Old Sep 2, 2006 | 02:52 PM
Heretic:Si's Avatar
Default Re: b16 compression test (Heretic:Si)
no one has any comments? maybe i should have asked what color to paint my valve cover
Old Sep 2, 2006 | 03:51 PM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si &raquo;</TD></TR><TR><TD CLASS="quote">no one has any comments? maybe i should have asked what color to paint my valve cover </TD></TR></TABLE>
Black...
Give it a week or two and check it again.I've seen readings go up and down sometimes.If it's still the same I still wouldn't worry about it.
Old Sep 2, 2006 | 09:42 PM
Garage 808 Hatch's Avatar
could need a valve job, or just a valve adjustment
Old Sep 3, 2006 | 08:20 AM
postman's Avatar
do a leak down test
Old Sep 3, 2006 | 08:28 AM
Heretic:Si's Avatar
Default Re: b16 compression test (postman)
thanks for the responses. valves were already adjusted, coworker did a leakdown and said everything was fine. his exact words "stop your worrying, you're too fu#@ing **** about your car"
civic-one
Apr 6, 2011 08:02 AM
MBlake55
Jul 27, 2009 04:56 PM
Brandon31386
Jul 23, 2006 10:56 PM
egvtec
May 24, 2005 05:32 PM
crxvtecturbo
Apr 18, 2005 08:51 AM
