Engine Rebuild ?
Old Aug 31, 2006 | 12:00 PM
QuarterMileMaster's Avatar
Default Engine Rebuild ?
Here's the deal. I'm rebuilding my GSR block with forged internals (stock c/r) and the head with ITR cams and valvetrain as well as an AEBS intake manifold. What I want to know is that will these things be ok to put on before the engine break in so I don't have to switch them all out later?? Or will in screw up the break in process?
Old Aug 31, 2006 | 01:48 PM
lightcrx's Avatar
u uselly get it tuned right away... but i dont see y you couldnt get away with it on a stock gsr ecu, i recomend getting a wideband at least and watching the a/f.
-joseph
Old Aug 31, 2006 | 01:53 PM
Default Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">u uselly get it tuned right away... but i dont see y you couldnt get away with it on a stock gsr ecu, i recomend getting a wideband at least and watching the a/f.
-joseph</TD></TR></TABLE>
Yeah, I'll have the wideband hooked up... I won't be driving it long or hard. I just want to be able to drive it back and forth from getting the charge piping and exhaust made...
Old Sep 2, 2006 | 06:08 PM
91SiZ6's Avatar
That'll be wasting the ring's break in time. Have it towed there and break it in on the way back. Advance your timing so it's a little on the rich side and you should be fine. You aren't doing anything really major.
Old Sep 2, 2006 | 11:07 PM
lightcrx's Avatar
y would advancing the timing make it run richer?? advancing timing would make the egt's increase meaning leaner, i guess i could be wrong tho..
-joseph
Old Sep 3, 2006 | 08:35 PM
91SiZ6's Avatar
More ignition timing = more fuel. Retarding the timing makes the EGTs run hotter.
Old Sep 3, 2006 | 08:41 PM
mmuller's Avatar
Mad Scientist
Default Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">More ignition timing = more fuel. Retarding the timing makes the EGTs run hotter.</TD></TR></TABLE>
actually, watch your AF's when you change timing....no change
you want your AF's the closest you can get them to stoich mixture for break in. just run closed loop
Old Sep 4, 2006 | 11:11 AM
Default Re: (mmuller)
Well, to avoid complication, I think I'm just going to keep everything stock for the break in. I'll just put everthing in after. Thanks!
absolut01gsr
Nov 1, 2008 09:31 AM
ryanxbar
Jun 21, 2008 09:49 AM
notorioussabo
Apr 7, 2008 05:41 PM
hb_rule_b18
Aug 22, 2005 03:48 PM
GSRwBOOST
Sep 7, 2002 05:36 PM
