H23 to H22A - No Spark at Distributor
Having some trouble with engine install. car was a H23, put a H22A in it, the H22A distributor has and internal coil & the H23 had a external coil. with the internal coil distributor on i have no spark. with the external coil distributor on i have spark but engine does not fire...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitchtsiawd »</TD></TR><TR><TD CLASS="quote">Having some trouble with engine install. car was a H23, put a H22A in it, the H22A distributor has and internal coil & the H23 had a external coil. with the internal coil distributor on i have no spark. with the external coil distributor on i have spark but engine does not fire... </TD></TR></TABLE>
Use the H23a distributor. Did you hook up the external coil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitchtsiawd »</TD></TR><TR><TD CLASS="quote">yeah the coil is hookup up and there is spark... but the engine won't fire</TD></TR></TABLE>
Ok, let's run through a few checks first:
1) Is this the first time trying to start the car?
2) Check for fuel pressure.
3) Check for compression.
You need 3 things to get an engine working: Spark, Fuel, Compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitchtsiawd »</TD></TR><TR><TD CLASS="quote">yes first time trying to start it
the engine is getting fuel
did not check compression yet, but the engine came from a good source...</TD></TR></TABLE>
Is it throwing any check engine lights yet? Also, what ECU are you running?
i believe the check engine light will come on when you turn the key to "ON", didn't notice if it stays light while cranking...
The engine was suppose to come with an ECU, but it was missing... so the company sent another one, and they state that it has been test and works... not sure on which one it is... did not see it stamped anywhere on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitchtsiawd »</TD></TR><TR><TD CLASS="quote">The engine was suppose to come with an ECU, but it was missing... so the company sent another one, and they state that it has been test and works... not sure on which one it is... did not see it stamped anywhere on it</TD></TR></TABLE>
The CEL will come on for a few seconds, then turn off if there are no codes. If it stays on, you'll need to pull the codes.
Secondly, is there a barcode sticker on the ecu? If so, you should be able to decipher what kind of ecu it is, there should be a "P13" in the numbers.
Also, did you use your stock wiring harness? Double check the connectors and make sure you didn't accidently plug in the wrong sensor. And did you wire up the two VTEC wires and IAB yet?
i did the same sway... H23si to JDM H22a
however i got the MSD external coil cap + a blaster SS coil..... if you are spending the money on the swap, may as well shell out another 65 bucks for those ignition parts.... made my life easy.
i was looking on the ecu for the code, i remember ther bar code, and i was looking for a P13 but didn't see it, i will check again...
no i have not hooked up those wires yet, i was told that it would make it not start though, unless i got some false info...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitchtsiawd »</TD></TR><TR><TD CLASS="quote">i was looking on the ecu for the code, i remember ther bar code, and i was looking for a P13 but didn't see it, i will check again...
no i have not hooked up those wires yet, i was told that it would make it not start though, unless i got some false info...</TD></TR></TABLE>
For the sake of troubleshooting, go ahead and hook EVERYTHING up before starting it.
ok so i got it started... i had to connect the black and yellow/black wires together where the external coil used to plug in... starts up and idles fine, put it in time.
Now it will hit the REV limiter at 3,000 no matter what...
But first things first, i know where the 3 wires for the VTEC go on the ECU, but was unsure about the IAB, i know where the pink wire goes but what about the other... ground?
car will not start with H23 distributor & external coil... i did use the H23 engine harness... car starts fine with H22 internal coil distributor with those two wires connected.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92blkJDMh22 »</TD></TR><TR><TD CLASS="quote">i did the same sway... H23si to JDM H22a
however i got the MSD external coil cap + a blaster SS coil..... if you are spending the money on the swap, may as well shell out another 65 bucks for those ignition parts.... made my life easy.</TD></TR></TABLE>
Waste of money on a stock motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitchtsiawd »</TD></TR><TR><TD CLASS="quote">car will not start with H23 distributor & external coil... i did use the H23 engine harness... car starts fine with H22 internal coil distributor with those two wires connected.</TD></TR></TABLE>
Are these the same ones you used on your h23, if so, it should work with them.
You need to find out for sure which ecu you're running.
Tell us the #'s stamped on the side, the middle three should say which
computer it is.
Have you tried using the p14 ecu just to see if it will work
with the external dizzy?
computer it is.
HotWheelz
Jan 25, 2003 10:29 AM
