piston ring gap, bearing clearence questions
Old Aug 31, 2006 | 07:06 AM
CivicVX94's Avatar
Default piston ring gap, bearing clearence questions
I'm going to have my engine built soon and i'm not sure on what ring gap to tell the builder to set it at...
the engine will be a DD b18b1 with wiseco pistons and eagle H beams...
any input on what would suit me best?
also, what bearings should i use? i'm leaning towards the ARP street bearings...
Thanks in advance for any help
Old Aug 31, 2006 | 08:09 AM
Sliced Beard's Avatar
Default Re: piston ring gap, bearing clearence questions (CivicVX94)
I suggest setting ring gap to the tight side of OEM specifications. I would first check with the manufacturer of your pistons to see if they have any reccomended gap specifications for use with their pistons, as they have different heat expansion rates over an OEM piston.
Old Aug 31, 2006 | 06:22 PM
NJIN BUILDR's Avatar
I assume by you sig you are turbo.I'm guessing you still 81mm.If that's the case I would gap both the top and second at .020".I would use oem specs for bearing clearances.If you can get that with the acl's then go for it.
Old Aug 31, 2006 | 07:17 PM
Combustion Contraption's Avatar
The rules are different with FOUR cylinder engines.
Old Sep 1, 2006 | 12:41 AM
CivicVX94's Avatar
Default Re: piston ring gap, bearing clearence questions (DirtySol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">I suggest setting ring gap to the tight side of OEM specifications. I would first check with the manufacturer of your pistons to see if they have any reccomended gap specifications for use with their pistons, as they have different heat expansion rates over an OEM piston.</TD></TR></TABLE>
ok cool, i'll look into that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">I assume by you sig you are turbo.I'm guessing you still 81mm.If that's the case I would gap both the top and second at .020".I would use oem specs for bearing clearances.If you can get that with the acl's then go for it.</TD></TR></TABLE>
yes i am turbo...and this setup will be for my new build...gt35 LS..hoping for 4--whp
would .020" for both gaps really be ok? i'll admit, idk **** about engine building at all..but i thought that would be a lot on the tight side?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">The rules are different with FOUR cylinder engines.
haha so let's hear your input
Thanks for everyone's help so far
Old Sep 1, 2006 | 10:46 AM
I was just kidding. NJIN BUILDR is always on the money with his recomendations and input.
Old Sep 2, 2006 | 05:57 PM
91SiZ6's Avatar
If your builder is known for building good and fast motors just let him do his thing. Assemble the motor yourself if you want to do your own blueprinting. From my experience, builders tend to get annoyed with people who tell them how to do their jobs. And if you're spending the money to build a motor why not spend a little extra on OEM bearings?
Old Sep 2, 2006 | 10:47 PM
CivicVX94's Avatar
Default Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote"> And if you're spending the money to build a motor why not spend a little extra on OEM bearings?</TD></TR></TABLE>
B/c i always heard that ACL are the way to go.
should i go oem and get the gsr bearings b/c they're a tri-metal bearing or something like that?
Old Sep 2, 2006 | 10:52 PM
ACL's are a tri metal as well.
Old Sep 3, 2006 | 12:09 AM
mmuller's Avatar
Mad Scientist
Default Re: (Combustion Contraption)
yeah, acl's are a good option if your tolerances allow for.
Old Sep 3, 2006 | 08:33 PM
91SiZ6's Avatar
ACL/King/Cleavite bearings = One Size Fits Most.
They're all sized for Honda's Green color. Honda has seven different bearing sizes for a reason. Put it to you this way, go to ImportBuilders.com and see what kind of bearings Jeff is using in his motors.
mobius346
Engine Machining & Assembly
Feb 15, 2019 01:32 PM
v8killaz
18
Jan 9, 2010 08:44 PM
Bangher4$
Nov 13, 2008 06:03 PM
SiTR
Aug 17, 2008 02:12 PM
xDicktonesx
34
Oct 25, 2006 05:58 AM
