civic swap help
Old Aug 31, 2006 | 01:04 AM
gregory's Avatar
Default civic swap help
what would all have to be changed for a B16A 92-95 (SiR-II) to fit in to a 92-95 civic coupe EX
Old Aug 31, 2006 | 01:38 AM
Froth's Avatar
Default Re: civic swap help (gregory)
Your search for B16a Swap returned 181 results.
Old Aug 31, 2006 | 04:32 AM
instrument's Avatar
i dont think that swaps been done before, hasport is still working on the mounts.
Old Aug 31, 2006 | 05:15 AM
singleslammer's Avatar
Default Re: (instrument)
You have to have b-series mounts, ecu, and wiring harness unless you have the sohc vtec motor in your car, then you can just use yours. You have to use b-series axles and intermediate shaft. From there you if you don't have the sohc vtec in your car then you have to wire up vtec. If you run a chipped ecu then you don't have to worry about the knock sensor, if you run the p30 b16 ecu then you have to wire up the knock sensor. Drop it in and have fun.
Old Aug 31, 2006 | 07:27 AM
spoonracer84eg's Avatar
Default Re: (singleslammer)
Just go with hmotorsonline.com for the complete swap. It will drop right in with the motor mounts that come with it and the shift linkage and axles will also work. Everything you get will work.
Old Aug 31, 2006 | 07:34 AM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">i dont think that swaps been done before, hasport is still working on the mounts.</TD></TR></TABLE>
hmmmmm
Old Sep 1, 2006 | 05:31 AM
Default Re: (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">Just go with hmotorsonline.com for the complete swap. It will drop right in with the motor mounts that come with it and the shift linkage and axles will also work. Everything you get will work.</TD></TR></TABLE>Yes, I agree, except for that they send right hand drive harness's don't they, so that could pose a problem. Not flaming you, just not 100% sure if it's a rhd harness. But no matter what, if you run the p30 ecu you have to wire up a knock sensor. If your car is not already vtec, then you have to wire that up. So it's up to you whether you wanna wire up 1. the vtec, or 2. the knock sensor.
Old Sep 1, 2006 | 05:33 AM
Okay, so I missed the whole 95 EX part, just buy a swap from h-motors, chip your ecu and it's cake from there.
Old Sep 1, 2006 | 05:36 AM
HNP's Avatar
HNP
why b16 go b18c....if u have an ex u barely need anything...everything the same mention on top........enjoy the beauty of a DOHC VTEC
Old Sep 1, 2006 | 05:38 AM
djsire's Avatar
Default Re: (HNP)
get an h22, then your really talkin!!
Old Sep 1, 2006 | 05:48 AM
If your gonna spend the money on a swap, save up a little more and buy the gsr swap, it's pretty straight forward.
Old Sep 1, 2006 | 06:15 AM
HNP's Avatar
HNP
yes, not for nothing but h22's are 2 complicated...i had one with a b-series trans but it was 2 much money...GSR is a beauty cause i had one too..
Old Sep 1, 2006 | 06:48 AM
Default Re: (HNP)
You can swap your d series wiring harness over if you want. If you use the rhd b series harness you will need to modify it a little bit. I would just use the d series. The only thing I had to do was find the O2 plug and cut it out of the harness so it would reach.
Old Sep 1, 2006 | 08:06 AM
So, you got your answers, now it's how much mechanical skills do you have?
phaphon
Apr 5, 2010 03:22 AM
Brandeezy1
Oct 31, 2009 12:41 PM
EGprojectkdkd
Jul 23, 2007 11:29 AM
usdmEHboy
Jan 7, 2007 09:32 PM
msinsky14
Mar 2, 2006 04:17 PM
