full b16a changeover on hmotors online ?
Old 02-28-2006, 06:04 PM
msinsky14's Avatar
Default full b16a changeover on hmotors online ?
does the b16a full changeover on h motors online have everything that is needed to fully swap it into a 1995 civic hatch?.......if not.......what else is needed because it says it comes with all sensors, does that include the knock too?
What about the shift linkage and mounts.......can the stock mounts be used for the swap......and what about the vtec oil pressure sensor?
Old 02-28-2006, 06:21 PM
JDMISACULT2's Avatar
Default Re: full b16a changeover on hmotors online ? (msinsky14)
You have to use the b16 mounts... yes it comes with everything you need all you need to do is run the wires for the vtec not too hard.
Old 03-01-2006, 02:33 PM
msinsky14's Avatar
Default Re: full b16a changeover on hmotors online ? (JDMISACULT2)
how come it doesnt have the wiring in the harness it comes with.........i thought i had to do something with the knock and oil pressure sensors too..........what about the axles it comes with?
Old 03-01-2006, 04:42 PM
JeffBro's Avatar
search. your asking about the MOST common swap done on the MOST common car for swaps. use the axles it comes with. and you can't use the jdm harness because its for a rhd car and the wires go to the wrong places. For a 95 hatch thats like the easiest swap there is...
Old 03-01-2006, 06:25 PM
msinsky14's Avatar
Default Re: full b16a changeover on hmotors online ? (JeffBro)
im getting the usdm anyway......so the harness should be able to fit
Old 03-01-2006, 06:33 PM
Larry Loveage's Avatar
i bought a B16a swap from Hmotorsonline and, if i remember right, they only carry JDM engines. It comes with everything but you have to modify the your harness if you don't have a VX or SI hatch. I had to replace the axles and all of the belts because they were worn.
Old 03-02-2006, 04:01 PM
msinsky14's Avatar
Default Re: full b16a changeover on hmotors online ? (Larry Loveage)
couldnt i just plug and play the harness that it comes with?........if i get usdm?
Old 03-02-2006, 04:17 PM
spuddo01's Avatar
you need the back mount bracket from a 99-00 si
gregory
13
09-01-2006 08:06 AM
msinsky14
03-27-2006 05:53 PM
BigPlansNoMoney
03-02-2005 05:32 AM
MUGEN_B16CIVIC
01-14-2004 06:47 PM
LD_EGSICK
20
02-04-2003 07:47 PM
Quick Reply: full b16a changeover on hmotors online ?
