What to buy for my REBUILD ??????????? please help
Old Aug 30, 2006 | 08:57 PM
eg4life1202's Avatar
Default What to buy for my REBUILD ??????????? please help
I am doing a rebuild on my stock internally B18C1.
Last week i heard some noticable rod knock from 2500 rpm to 3500 rpm
i am planning to do a complete block tear down and rebuild for high compresstion pistons 12.4 to 1
what should i buy besides:
pistons, piston rings, rod bearings, remachine the crank, and oil pump
i want it to be as reliable as possible
thanks for the info
Old Aug 30, 2006 | 08:59 PM
-Championship-'s Avatar
76.169.175.137
Default Re: What to buy for my REBUILD ??????????? please help (eg4life1202)
whole lot of compression, good luck running 100 octane it drove me insane!!!...anywho umm eagle f*in rods man and rod bolts
Old Aug 30, 2006 | 09:00 PM
qfast817's Avatar
well i wouldnt do 12 to 1, pr3 pistons are good for daily. for the rod knock check the bearings and reblance the crank
76.169.175.137
Default Re: What to buy for my REBUILD ??????????? please help (CW_98gsr)
if your going with that process i would consider looking for a ls crank, but try to lose the pistons, i believe the ls crank will raise compression, just go lower compression like 11 to 4 and your set
Old Aug 30, 2006 | 09:02 PM
Dartanian's Avatar
Buy a whole gasket kit. Main and thrust bearings are also a good idea.
Old Aug 30, 2006 | 09:27 PM
thanks for the input
bump
1995Civiccx
Feb 6, 2008 01:56 PM
loudassVTEC
Jun 30, 2006 03:45 AM
001020
Mar 20, 2005 06:52 PM
ill_take_one
28
Feb 25, 2003 09:00 PM
Trajic
Oct 8, 2001 11:00 PM
