94 accord changing O2 sensor-special socket...do i really NEED this?
Old Aug 30, 2006 | 05:54 PM
coolrahool's Avatar
Default 94 accord changing O2 sensor-special socket...do i really NEED this?
I'm gonna change my o2 sensor and i understand that i need a special socket in order to remove it, however; could i not just remove the large cover (i see 2 bolts that hold it in place) that the sensor is screwed into and the simply use a regular open ended wrench to remove/replace it? where i a m shops don't rent that socket and its #0 to purchase it.
Old Aug 30, 2006 | 06:15 PM
hondadude's Avatar
Default Re: 94 accord changing O2 sensor-special socket...do i really NEED this? (coolrahool)
Even if you remove the exhaust shroud I don't think there is room for a wrench.
Old Aug 30, 2006 | 07:35 PM
BlUAc's Avatar
Default Re: 94 accord changing O2 sensor-special socket...do i really NEED this? (hondadude)
ya you can I just did one on my boy 96 accord and I just used an open end wrench
Old Aug 30, 2006 | 07:46 PM
coolrahool's Avatar
Default Re: 94 accord changing O2 sensor-special socket...do i really NEED this? (BlUAc)
Ok kool...i'll try it that way then. DID you remove the big metal cover that the tip is covered by?
Old Aug 30, 2006 | 07:57 PM
momstaxi's Avatar
yes, remove the heat sheild
Old Aug 30, 2006 | 10:12 PM
iam7head's Avatar
Default Re: 94 accord changing O2 sensor-special socket...do i really NEED this? (momstaxi)
no need, just use a SAE wrench, one of the size is a perfect fit for o2 sensor
Old Sep 1, 2006 | 03:00 PM
coolrahool's Avatar
Default Re: 94 accord changing O2 sensor-special socket...do i really NEED this? (iam7head)
Everything worked like a charm and yes you can save the hastle of buying or renting that special socket by taking off that metal heat shield (3 bolts) and then a 7/8 SAE wrench does the trick perfectly!
Old Sep 1, 2006 | 04:31 PM
AccordStuntin's Avatar
Hey...how hard was your to take off? I have been trying to get mine off for a couple days now and it wont move! I even sprayed thrust on and let it soak and sprayed it again! Let me know
Old Sep 1, 2006 | 05:25 PM
coolrahool's Avatar
Default Re: 94 accord changing O2 sensor-special socket...do i really NEED this? (AccordStuntin)
i just used a a ratchet set with a 12mm socket ialso used a bit od Wd40 .just make sure your car is cooled down
Old Sep 2, 2006 | 12:32 AM
SuperSlow's Avatar
if you are having trouble. put on some heavy heavy gloves and padded coveralls, and try taking it off when it is hot.
don't burn your face.
Old Sep 2, 2006 | 02:53 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolrahool &raquo;</TD></TR><TR><TD CLASS="quote">i just used a a ratchet set with a 12mm socket ialso used a bit od Wd40 .just make sure your car is cooled down</TD></TR></TABLE>
probably not, 12mm? honda?
it's much easier to take it out with it slightly heated actually
Old Sep 2, 2006 | 03:03 PM
RotaryBzzzz's Avatar
You can borrow the special o2 sensor tool set from Autozone for free.
Old Sep 3, 2006 | 11:32 AM
BlUAc's Avatar
Default Re: 94 accord changing O2 sensor-special socket...do i really NEED this? (RotaryBzzzz)
that socket with the slit down the side for the wiring is shitty and worthless it opens up and not grip the o2 sensor after you use it a couple of times
Benevolent27
Jul 12, 2010 01:26 PM
EG-SIXV-TEC
Feb 7, 2009 01:14 PM
coolrahool
Aug 23, 2006 05:09 PM
beandip
Feb 20, 2006 10:00 AM
neilff
Jun 10, 2003 08:29 PM
