My prelude wont start!! Help!
Old Aug 30, 2006 | 12:05 PM
tn265's Avatar
Default My prelude wont start!! Help!
ok..all i did was unplug my stereo deck and plug that **** back in and put it back in place. Afterwards i tried to start my car and it made a wierd noise for a 10 seconds then it went away. the problem is that wen i try to start my car my deck turns off and the antenna goes down and the car wont start. Could it be a blown fuse? im clueless.. please help!!
Old Aug 30, 2006 | 12:16 PM
98vtec's Avatar
moderator emeritus
Default Re: My prelude wont start!! Help! (tn265)
have you not checked your fuses?
we cant diagnose problems like this over the internet without you getting your hands dirty and taking a look for yourself.
Old Aug 30, 2006 | 12:52 PM
MadCityLude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tn265 &raquo;</TD></TR><TR><TD CLASS="quote">ok..all i did was unplug my stereo deck and plug that **** back in and put it back in place. Afterwards i tried to start my car and it made a wierd noise for a 10 seconds then it went away. the problem is that wen i try to start my car my deck turns off and the antenna goes down and the car wont start. Could it be a blown fuse? im clueless.. please help!!
First off why did you unplug and replug your stereo? Was the battery disconnected when you did it? Is the battery charged?
Old Aug 30, 2006 | 12:57 PM
Perfectionist's Avatar
By the way everything shuts down, it sounds like the battery doesn't have enough poop to crank the engine and relays were just chattering.
Either the battery is crap or is severely discharged.
Old Aug 30, 2006 | 03:05 PM
tn265's Avatar
Default Re: My prelude wont start!! Help! (Perfectionist)
ok i checked out all the fuses and none seems to be blown or none that i believe to be.just to be sure how do you guys check if a fuse is blown or not?. but yeah.the car still wont start.
Old Aug 30, 2006 | 03:13 PM
mgags7's Avatar
your battery is dead dude
Old Aug 30, 2006 | 06:29 PM
tn265's Avatar
Default Re: (mgags7)
alrite..i tried to jumpstart the battery but my car would still not start. i find it really wierd how if i try to turn the car on my deck turns off and the antenna goes down..plus the ac panel turns off as well...i need help you guys.
Old Aug 30, 2006 | 06:49 PM
MadCityLude
Guest
Posts: n/a
Default Re: (tn265)
Maybe you have some sort of short in the dash. What exactly did you do when you pulled your deck out? Why did you remove it? Tell us anything you changed at all. Try disconnecting the deck and starting it.
Old Aug 30, 2006 | 08:42 PM
tn265's Avatar
Default Re: (MadCityLude)
ok what i did was trying to install my in dash kit for my deck so i unplugg my deck and the antenna cord. after i put in my deck i tried to turn on my car and it made thsi weird sqeeking noise that it never made before for about 10 seconds, then it went away. I tried unpluggin the deck again and turn on the car but it still wouldnt turn on. all the ligtings works but wen i tried to turn on the engine the deck gives out an dthe antenna goes back down. i have no idea why it is doing this. i didnt check the four big block of fuses under the hood in the top left because i dont know how to check thoes. i dont wanna spend money for the shop..please help man
Old Aug 30, 2006 | 10:24 PM
djcue_530's Avatar
Default Re: (tn265)
hey check ur ig switch relay..its under the hood of ur car @ the fuse box..it says lg sw..check to see if the fuze looks burnt..if so replace it..its only like 2 bucks @ napa..if thats not the case..check for ur main relay ...its located under the driver side dash..u can find it if u unplug where the cruise controls @ and the sunroof buttons @ ..remove that and behind that will be ur main relay.(its just a lil grey box).its pretty expensive..it runs about 70 bucks @ the dealer..but first open the relay and check it out first..try cleanig it by scrapn it off with a knife. scrape around the tacked parts..not the green part of the relay!..
Old Aug 30, 2006 | 10:32 PM
mgags7's Avatar
if your battery is not dead then you have either dirty battery cables built up with corrosion, or you have a loose ground somewhere
i would clean the battery wires and replace all the grounds
Old Aug 30, 2006 | 10:34 PM
98vtec's Avatar
moderator emeritus
and make sure the ground on the alternator isnt corroded.
Old Aug 30, 2006 | 10:57 PM
MadCityLude
Guest
Posts: n/a
Default Re: (djcue_530)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djcue_530 &raquo;</TD></TR><TR><TD CLASS="quote">hey check ur ig switch relay..its under the hood of ur car @ the fuse box..it says lg sw..check to see if the fuze looks burnt..if so replace it..its only like 2 bucks @ napa..if thats not the case..check for ur main relay ...its located under the driver side dash..u can find it if u unplug where the cruise controls @ and the sunroof buttons @ ..remove that and behind that will be ur main relay.(its just a lil grey box).its pretty expensive..it runs about 70 bucks @ the dealer..but first open the relay and check it out first..try cleanig it by scrapn it off with a knife. scrape around the tacked parts..not the green part of the relay!..</TD></TR></TABLE>
This is FALSE INFO.
The main relay wouldn't cause problems like that.
The IG switch or whatever I don't know about that.
Prelu BOy
Apr 27, 2010 11:12 PM
CeoStatus0
Sep 20, 2008 07:17 AM
sii.
Jan 29, 2007 10:24 PM
flaxx0r
22
Oct 2, 2006 12:06 PM
