HU install questions. 98 EK (i did a search but, couldn't find anything useful.
Old Aug 30, 2006 | 10:37 AM
ctrld-kaos's Avatar
Default HU install questions. 98 EK (i did a search but, couldn't find anything useful.
I picked up a new alpine head(9852) unit and ive wired the harness up and im ready to go. The thing is I want to install it in the DIN infront of the cup holders(98 EK/EJ). I searched but i couldn't find a good write up on this. I know its not a direct fit, anybody have any tips or tricks on putting the head unit in properly? Any feed back is appreciated.
Old Aug 30, 2006 | 11:10 AM
vicn77's Avatar
Default Re: HU install questions. 98 EK (i did a search but, couldn't find anything useful. (ctrld-kaos)
it should fit in there fine. you have to take out the armrest, if you have one, and the console surrounding the cupholder and din pocket (or tape player). from there you should be able to mount the radio where the pocket was, just have to drop the wires down to plug them into your alpine.
Old Aug 30, 2006 | 11:33 AM
ctrld-kaos's Avatar
Default Re: HU install questions. 98 EK (vicn77)
Do i have to do anything to keep it from jiggling around? Because I have a feeling that its not going to fit snuggly.
Old Aug 30, 2006 | 01:49 PM
CarbonizedDX's Avatar
Default Re: HU install questions. 98 EK (ctrld-kaos)
On mine I purchased a new unit due to lack of the mounts, but with the new-used unit there were four bolt openings (two on either side) that holds the factory cd/tape player. All I had to do was slide the deck in, line up the deck with the screw holes and use the supplied screws to screw it in. The wiring harness and antenna should be able to be re-routed with out any troulbe, I just pulled mine down and it that was that.
I've seen some people use the stereo's din metal bezel mounting sleeve and that works just the same as in the OE position, mount the bezel and slide the deck in. In my case tho the bezel didn't fit (might be the difference between the cd/tape player and the cubby pocket openings) and I like the hard mounted option way better.
Old Aug 30, 2006 | 03:01 PM
ctrld-kaos's Avatar
Default Re: HU install questions. 98 EK (CarbonizedDX)
Cool deal man, thanx for the info!
Old Aug 30, 2006 | 03:54 PM
fcm's Avatar
fcm
Old Fart
Why do you not want to install it in the stock location? 94
Old Aug 31, 2006 | 06:46 AM
ctrld-kaos's Avatar
Default Re: HU install questions. 98 EK (fcm)
because im going to put my a/f, oil temp and exhaust temp guages in the stock location.
Old Aug 31, 2006 | 06:49 AM
fcm's Avatar
fcm
Old Fart
OIC, do you have OEM key-less entry on your car? 94
Old Aug 31, 2006 | 11:06 AM
ctrld-kaos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">OIC, do you have OEM key-less entry on your car? 94</TD></TR></TABLE>
Nope, im going to install an aftermarket keyless entry sys along with a new alarm.
Old Aug 31, 2006 | 02:31 PM
fcm's Avatar
fcm
Old Fart
OIC. 94
STOCK_SOHC_DX
Audio / Security / Video
15
Nov 18, 2024 12:31 PM
vietintegboi
Nov 21, 2006 04:23 PM
LShatchboy
19
Nov 13, 2006 02:15 AM
pushlatency
Jul 24, 2005 09:59 AM
JMod
Aug 19, 2003 01:38 PM
