timing belt came off, how long can i drive it?
um.. if your timing belt "came off" your engine wouldn't be running.. and you'd probably have bent valves.
Are you sure it wasn't the belt for power steering, the alternator and all that jazz?
the belt is inside the plastic cover not the outside where the alternator and power steering belt are located...........i dont understand.......the car runs and drives.......wtf??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Log4n »</TD></TR><TR><TD CLASS="quote">n/m it was the water pump </TD></TR></TABLE>
waterpump is driven by the timing belt....
just a faulty waterpump?
waterpump is driven by the timing belt....just a faulty waterpump?
NO offense but i don;t think you got a clue of what the hell you are talking about
the water pump what ?? was noisy??
pump cannot come off, it can leak or make noise ,, t-belt cannot come off and car still run
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">um.. if your timing belt "came off" your engine wouldn't be running.. and you'd probably have bent valves.
Are you sure it wasn't the belt for power steering, the alternator and all that jazz?</TD></TR></TABLE>
listen to this guy. we have what is called an interferance engine, and it sounds like you unfortunately found that out the hard way. slipped timing belt = head work
aznromeo4u
Feb 18, 2015 07:51 PM
lankan-balla
Mar 8, 2013 01:02 PM
