Help Code 15... Ignition?
Old Aug 29, 2006 | 07:59 PM
abazidustin03's Avatar
Default Help Code 15... Ignition?
About a week ago, i bought a new engine for my 1990 honda accord ex 4 door. The stock motor was a F22A4 Manual trans. I put in a F22A1, but i swaped out the automatic trans with a manual trans. I bought a brand new distributor, the cap rotor, and spark plugs. But i'm getting no spark. All the fuses and relays are good, and the motor is turning and recieving fuel. I just don't know what to do. I pulled the carpet up on the passenger's side and noticed the computer flashing a code 15. I'm so bumed i'm about ready to put it on a trailor and take it to the honda dealer and let them fix it. First i decided to run it by the forum. Any info or ideas will help!!!
Old Aug 29, 2006 | 09:20 PM
momstaxi's Avatar
Default Re: Help Code 15... Ignition? (abazidustin03)
code 15 commonly refers to either,
faulty ignition control module, possibly faulty main relay, or problems with the cap/rotor
Old Aug 29, 2006 | 10:04 PM
Honda-Master's Avatar
Default Re: Help Code 15... Ignition? (momstaxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi &raquo;</TD></TR><TR><TD CLASS="quote">code 15 commonly refers to either,
faulty ignition control module, possibly faulty main relay, or problems with the cap/rotor</TD></TR></TABLE>
wrong amigo..........code 15 is for the ignition output signal
main relay will not cause that neither will cap or rotor
only the ignitor of the things you mentioned could cause code 15
Old Aug 30, 2006 | 07:19 AM
JimBlake's Avatar
Default Re: Help Code 15... Ignition? (Honda-Master)
Only the ignitor, or a messed-up circuit from ECU to ignitor.
Old Aug 30, 2006 | 06:00 PM
Do you know where the main relay is on a 1990 Honda Accord EX YOu have been alot of help i really appreciate it - dustin
Old Aug 30, 2006 | 06:11 PM
hondadude's Avatar
Connect the ground at the T-stat housing
90crvtec
Aug 19, 2005 07:19 PM
Ivanushka
Jul 25, 2004 03:16 PM
SOHC_MShue
16
Dec 4, 2003 07:16 PM
shorty91
Jun 27, 2003 07:55 PM
