booster or master cylinder
Old Apr 27, 2002 | 02:57 PM
KekeK-18's Avatar
Default booster or master cylinder
I just got a 1" mastercylinder and booster from a junkyard. When I'm driving, I always get good pedal pressure if I brake and let go. But if I don't let go and just keep pressuring the brake the pedal, it will sink gradually to the bottom. I'm 100% sure there are no air in the fluid......What do you guys think?? The MC or the booster?
[Modified by KekeK-18, 10:12 PM 4/27/2002]
Old Apr 27, 2002 | 03:38 PM
boosted3g's Avatar
Default Re: booster or master cylinder (KekeK-18)
If you didnt change the slave then its probably a bad master that you got from the yard. Check under the dash at the firewall and see if you can see any fluid. that would be a sure sign. I highly doubt the booster is bad, they last forever.
Old Apr 27, 2002 | 05:44 PM
Chiovnidca's Avatar
I just got a 1" mastercylinder and booster from a junkyard. When I'm driving the car the I alway gets good pedal pressure if I brake and let go. But if I dont let go and just keep presurring the brake the pedal will sink gruadually to the bottom. I'm 100% sure there are no air in the fluid. Its either the master cylinder or the booster.....What do you guys think??
Try checking your fluid level then push the pedal down to the floor a few times. Then check your fluid level again, you may have a leak somewhere. If not I suspect the master cylinder is crap.
Old Apr 27, 2002 | 06:19 PM
KekeK-18's Avatar
Default Re: booster or master cylinder (Chiovnidca)
So you guys are betting on the MC and not the Booster? Any test I can perform to find out which went bad?
Old Apr 28, 2002 | 12:14 AM
riceboy's Avatar
Its the master cylinder, theyre pretty fairly priced from the dealership.
mattbatson
Oct 23, 2008 07:30 PM
ilvi3tkidxx
Oct 16, 2008 06:51 PM
mattmw88
Mar 31, 2008 06:08 PM
bb4socal
Sep 4, 2006 09:51 PM
KekeK-18
10
Apr 28, 2002 09:38 PM
