trouble with removing speedo cable from tranmission
Old Aug 29, 2006 | 06:33 PM
drew2's Avatar
Default trouble with removing speedo cable from tranmission
Cable broke and the "tip" on it where it goes into the housing on the tranmission is still there. How can i get this out? Can i remove the whole housing from the tranmission? I unbolted the housing but the flat piece broke off
Old Aug 29, 2006 | 06:39 PM
civickiller's Avatar
Default Re: trouble with removing speedo cable from tranmission (drew2)
that flat piece comes off, its seperate. i couldnt get my d series vss out, i was trying and i finally gave up. yours might be easier because it will be easier to get that tip out with the whole unit out of the tranny
Old Aug 29, 2006 | 06:45 PM
drew2's Avatar
Default Re: trouble with removing speedo cable from tranmission (civickiller)
haha, ****, i think i threw the flat piece out.....ugh
Old Aug 29, 2006 | 06:50 PM
pandarex's Avatar
spray a little wd40 around the edges, and wiggle the vss back and forth, it will eventually come out
THE *FOB* MOB
Nov 16, 2016 12:28 PM
integraNooB
Oct 16, 2008 09:40 AM
b17gsr
Jun 25, 2003 07:27 AM
LD_EGSICK
Dec 4, 2002 12:00 PM
