car died.. replaced distributor, car works.. 2 miles later car dead again?!?
anyone got any idea why this happened? car was running great with the swapped distributor.. started right up!! now it appears the same thing has happened..
92 civic dx with d16 minime.. has been running fine for 2 years now...
car turns over... no apparent spark coming from the wires... just suddenly stopped while driving.
Re: car died.. replaced distributor, car works.. 2 miles later car dead again?!? (bushfreakz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bushfreakz »</TD></TR><TR><TD CLASS="quote">anyone got any idea why this happened? car was running great with the swapped distributor.. started right up!! now it appears the same thing has happened..
car turns over... no apparent spark coming from the wires... just suddenly stopped while driving.</TD></TR></TABLE>
alternator... battery...
acctual plug wires..
Re: car died.. replaced distributor, car works.. 2 miles later car dead again?!? (EGwhat!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! »</TD></TR><TR><TD CLASS="quote">internal coil maybe</TD></TR></TABLE>
isn't coil in the distributor?
he just replaced it
he just replaced it
battery is fine... wires are fine.. alternator should be ok right?
distributor died.. we replaced it 2 hours later.. and car started up.. driving again trying to get to work.. and it dies again.. same symptoms.. still have battery and im actually sitting in the car right now.. i got wifi baby!!!
Re: car died.. replaced distributor, car works.. 2 miles later car dead again?!? (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">
he just replaced it</TD></TR></TABLE>
yeah put doesnt mean he changed it
Re: (bushfreakz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bushfreakz »</TD></TR><TR><TD CLASS="quote">battery is fine... wires are fine.. alternator should be ok right?
distributor died.. we replaced it 2 hours later.. and car started up.. driving again trying to get to work.. and it dies again.. same symptoms.. still have battery and im actually sitting in the car right now.. i got wifi baby!!!</TD></TR></TABLE>
hmm, your spark plugs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! »</TD></TR><TR><TD CLASS="quote">yeah put doesnt mean he changed it</TD></TR></TABLE>
did you replace the WHOLE distributor? including the ignition coil? he might of just replaced the cap and rotor.. the ignition coil runs about 80 bbucks.. pulll spark plug out.. hold it in wire.. and try n crank the car.. but have it grounded. if there is no spark then it ost likley is your ignition coil... they tend to take a **** after a while.. just replaced mine hte other day without no problems.
yes the distributor came out of another car it worked...
and it continued to work for awhile in this other car... i cannot throw it back into the other car now because that car has the head off of it right now.
Re: (bushfreakz)
check the resistance of the coil and check the icm too, for proper operation while the coil is still in the car. here is the site http://jdmlyfestyle.com/how_to...m.htm
i had the same problem as you but i got a new distributor from ebay and had everything (worth the money) and it worked after a couple cranks. goodl uck
rodvang
01-09-2008 05:45 AM
whatcivic
11-05-2007 03:19 PM
