68mm Skunk2 T/B and stock TPS Setting and car will not idle
Old Aug 29, 2006 | 11:45 AM
reddevil94's Avatar
Default 68mm Skunk2 T/B and stock TPS Setting and car will not idle
I am running this TB on a Skunk2 Pro Series manifold and the gasket is not cutout for the manifold running a IACV, so I cut it out and it still will not idle. Thinking the IACV will work. SHould I run the TPS at the stock setting same as the honda manual or is there a different position that it should be set since it is a aftermarket TB. Thanks for you help.....
Old Aug 29, 2006 | 09:23 PM
Garage 808 Hatch's Avatar
you need to recalibrate the tps to stock perameters
reg_lus
Jul 17, 2022 10:03 AM
z6sedan
30
Jan 23, 2016 03:57 PM
matt_pound
Dec 3, 2006 07:16 PM
snowblind7x
Jul 12, 2006 06:52 AM
germanEE8
Feb 25, 2004 08:56 AM
