new clutch problem!!HELP
Old Aug 29, 2006 | 11:20 AM
90hbvtec's Avatar
Default new clutch problem!!HELP
ok i installed my new exedy clutch stage 1 along with a lighten flywheel..installation went fine..started up the car..started up fine..i let it idle for alittle..now tried to shift into gears it would not..it would go into gear but very hard to shift into gear..what could it possibly be, did i install the clutch wrong.? if i did would the car even start up?...slave cylinder?..MC?..i bleed the clutch line..but no diffrent maybe just very little diffrence..unless i did the bleeding part wrong..HELP
Old Aug 29, 2006 | 11:15 PM
1SiC 3DR's Avatar
Default Re: new clutch problem!!HELP (90hbvtec)
i had the same problem with my 1994 coupe when i first got the motor in and i had to adjust the clutch pedal under the dash it wasnt fully releasing the clutch - just my 2 cents
jdmcivicracer89
21
Jun 5, 2008 09:39 AM
TOP END MS
Dec 15, 2006 07:06 PM
90hbvtec
Aug 31, 2006 07:33 PM
tianporn
Nov 5, 2004 12:18 PM
Pikachu
Nov 24, 2003 04:15 AM
