EVO 8 turbo stuff install (tips?)
Ok I have a 91 CRX with a JDM obdo B16. My friend is selling me his EVO 8 turbo stuff. This includes (turbo (20G), intercooler (not sure if i can even use it), injectors (I'm assuming they are 450's correct me if I'm wrong), manifold, downpipe, and piping. I know there is gonna need to be a lot of fabbing on my part. I only want to run like 5 pounds because i don't have enough money to convert to obd1 and run hondata so I'd like to know if my ECU can run the evo 8 injectors, and what can i do to make it only run 5-6 pounds not to sure with it being internally wastegated and all. and any other tips on manifolds to run. I want to to this as cheap as possible without being completely ghetto. and help is greatly appreciated! thanx
-RussHondaCRX
-RussHondaCRX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot »</TD></TR><TR><TD CLASS="quote">if you don't have the $$$$, save until you do and do it right the frist time..</TD></TR></TABLE>
Very true but alot of people are happy with turbo edit for obd0.
You do know most of that stuff you won't be able to use and I'm not a huge 20g fan myself.
I'm not too familar with evos so someone else will have to chime in about the injectors.
it should be internal wastegate, which is better if your running low boost....but in all honesty that turbo is waaaaaaaaaay too big if ure gonna run only 5 pounds...and on the injectors, if you have a multi meter check the resistance across the terminals and see if they match that of the older dsm blue tops...if so, you should be able to run them...but don't quote me on that, just my .02
and like somebody above me said, just wait till you have the money and do it right, your gonna end up selling 80% of the stuff ure getting from that kid cuz it wont work, and the other stuff you get isn't really fit for your use
grab all of it if you can, the injectors are 550, you can use them or sell the ic wil work and the 20g turbo you can sell to a dsm for some cash or trade with his turbo
mortificationrock
Aug 10, 2008 11:31 AM
