oil pan bolt stripped out what can i do.
Old Aug 29, 2006 | 07:33 AM
si90rex's Avatar
Default oil pan bolt stripped out what can i do.
ok i tried a oversized one, and rubber washers but nothing has helped. so i going to get an aftermarket oil pan does any bubby know were i can get one for a good price.
thanks
Old Aug 29, 2006 | 07:35 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: oil pan bolt stripped out what can i do. (si90rex)
I had the same problem, got one new on ebay for a good price.
Old Aug 29, 2006 | 07:38 AM
EL Vap133's Avatar
Just get a new stock one from the dealer and replace it, it comes with the bolt and washer.
Old Aug 29, 2006 | 03:17 PM
saaron34's Avatar
Default Re: oil pan bolt stripped out what can i do. (EL Vap133)
when you take the pan off to put a new one on, be VERY careful when tightening the nuts. I twisted off two of the studs from the engine-side because I didn't pay attention to how much torque you are supposed to put on them. Luckily I didn't have any leakage problems, but still. I was pissed at myself.
Old Aug 29, 2006 | 03:19 PM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Just get a new stock one from the dealer and replace it, it comes with the bolt and washer. </TD></TR></TABLE>
Or just get one from the junkyard and make sure its ok. Also, if you get one from the junkyard clean it out as best you can.
Old Aug 29, 2006 | 05:14 PM
efhonda91's Avatar
Default Re: oil pan bolt stripped out what can i do. (nicks_jdmstyle_ef9)
If you need a quick fix you can get something called a pan saver too. Any auto store should have them.
liquidx
Aug 8, 2010 03:58 PM
allricedout
Jun 17, 2007 11:02 AM
EikoU
Jun 12, 2006 08:14 PM
MechEng
Oct 21, 2005 12:14 PM
the.hamburglar
24
Jul 19, 2005 08:39 PM
