Rear swaybar install - subframe
Re: Rear swaybar install - subframe (Eyal 951)
I am not sure about the older Civics, but on the 01-05, anything less than an EX did noot come predrilled with spots. They make an adapter kit for it.
With that being said, I think 96-2000, any non-Si did not come with it. Somebody correct me if I am wrong.
Re: Rear swaybar install - subframe (sicones)
on the 92-95 the sub frame was already drilled for the mounts. You will need the lower control arms for the swap the only civics that had the control arms set up for a sway bar already had one. Acura Integras from 94 and up had the correct parts and are a direct fit to the car. Also I was told the 4dr civic ex had a rear sway bar
Re: Rear swaybar install - subframe (instructor74)
ok, thanks guys. I have the control arms already (Full GSR swap front and rear) Just wanted to know if its a bolt on affair. Any tear out issues with a s tock gsr bar? I will use an asr brace when I change to usdm ITR, but for now, the small 13mm shouldn't be an issue correct?
Unceasing Measure
Re: Rear swaybar install - subframe (BlueIntegraBoy)
On an EG, there are holes in the rear subframe already <FONT COLOR="red">but you will have to widen them with a drill bit of the appropriate diameter if the car did not come with a stock swaybar.</FONT>
Just keep that in mind before you get under there and start getting frustrated.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyal 951 »</TD></TR><TR><TD CLASS="quote">widening is no propblem I geuss. I just use a nut on the inside?</TD></TR></TABLE>
yessir
yessir
Re: Rear swaybar install - subframe (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">On an EG, there are holes in the rear subframe already <FONT COLOR="red">but you will have to widen them with a drill bit of the appropriate diameter if the car did not come with a stock swaybar.</FONT>
Just keep that in mind before you get under there and start getting frustrated.</TD></TR></TABLE>
not always true, my 94 ex already had the holes in the subframe and bolts tack welded on from the factory, I replaced the lca's with teg ones and everything bolted up
gl
gl
DerangedEG
05-14-2004 11:48 AM
