Boost on a triumph boneville?...
Old Aug 28, 2006 | 05:00 PM
Foowee's Avatar
Default Boost on a triumph boneville?...
Think 360 degree parallel twin. Pistons rise and fall together. No exhaust valves open at the same time...
Do you kids think a normal undivided turbine on this engine would have the same quick spool characteristics as a split turbine on a 180 degree inline 4? Thoughts, opinions, ideas???...
Old Aug 28, 2006 | 05:15 PM
ricepapertiger's Avatar
Well someone's done it already, dunno if you googled a little bit and found this: http://www.boostisgood.com/start.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostisgood.com &raquo;</TD></TR><TR><TD CLASS="quote">We use the Aerocharger Turbo which is self lubricating, has ball bearings and has variable vane geometry. Our boost comes on at 2500rpm and even in stage 1 we have almost 100ft*lbs of torque at 5500rpm. The throttle response is very linear. We specialize in Triumphs and Harley Davidsons, so you can rest assured that our system will work properly on your bike without modifications...</TD></TR></TABLE>
Dollar_bill
Sep 14, 2006 02:50 PM
LSVtechnologytur...
May 2, 2005 05:18 PM
Sam1am26
Nov 26, 2004 06:51 PM
HotRodTeg
Oct 4, 2003 12:27 AM
hotboi850
Aug 30, 2003 08:59 AM
