C.R. B16A2 head on B18c1 bottom end?
Old Apr 27, 2002 | 08:45 AM
6ghatch's Avatar
Default C.R. B16A2 head on B18c1 bottom end?
Does anyone know if it will change the compression ration if I put a B16a2 head on a b18c1 block?
Old Apr 27, 2002 | 09:27 AM
allmtr's Avatar
Default Re: C.R. B16A2 head on B18c1 bottom end? (6ghatch)
it will drop because the b16 combustion chamber is slightly bigger. should be around 9.8:1
Old Apr 27, 2002 | 12:19 PM
6ghatch's Avatar
So If I were to upgrade my bottom end on my b16a2 what would you suggest for daily driving and reasonable price? What compression would I get with the JDM CTR or ITR pistons on that setup?
Old Apr 28, 2002 | 12:16 AM
EF_LSVtec's Avatar
Why downgrade?
Old Apr 28, 2002 | 12:38 AM
Katman's Avatar
wait a second....do you have a B16A or B18C block? you're confusing some of us.
If you have a B16A block, running CTR pistons + B16A head should put in the range of 11.0 compression ratio. If you go JDM ITR pistons it will put you up to about 10.6-7 cr.
Old Apr 28, 2002 | 04:23 AM
6ghatch's Avatar
Default Re: C.R. B16A2 head on B18c1 bottom end? (Katman)
I'm sorry, what I ment was If I were using my B16a2 head and changing to a B18c1 block, what would the CR ratio be with the CTR and ITR pistons? Would this be the best way to go? Should I use ITR or CTR rods also? Or should I just buck up for a ITR block?
Right now I've got B16a2 with Comptech Icebox, Skunk2 intake manifold, stage 1 cams, valve train, cam gears, JDM ITR header, CTR N1 crank pulley, test pipe, Skunk2 ecu, and Fields VTEC/Fuel controller. I've dynoed at 171whp with this setup and I'm looking for a bit more torque and around 190+whp.
Thanks, any other suggestions would be appreciated!
[Modified by 6ghatch, 6:18 AM 4/28/2002]
Old Apr 28, 2002 | 02:32 PM
eg6ajk's Avatar
with USDM ITR pistons = 10.6:1 (same as USDM ITR) - JDM ITR pistons 11:1
CTR pistons = 11.8:1
B16A PR3 piston = 11.2:1 with a JDM second gen P30 piston 11.4:1
Old Apr 29, 2002 | 06:24 AM
6ghatch's Avatar
Default Re: C.R. B16A2 head on B18c1 bottom end? (eg6ajk)
Thanks!
[Modified by 6ghatch, 7:25 AM 4/29/2002]
Old May 4, 2002 | 06:00 PM
Turbo Laser's Avatar
If you get the CTR pistons and some headwork you should be at 190hp. Good luck!
Old May 4, 2002 | 07:42 PM
Malice's Avatar
New User
Default Re: C.R. B16A2 head on B18c1 bottom end? (ZCTURBO)
hey im going to be doing that setup, except my B16 head is being portrd and polished by portflow with that should i break 200whp?
complete new setup on my 95 GSR motor:
p/p first gen B16a (PR3) head by portflow
ITR intake manifold
Skunk2 valvetrain w/ stage 1 cams ( already have these cams in my gsr now)
B16 pistons
ITR tranny
TODA flywheel (9lbs)
Mugen head gasket
5zigen header
Carsound cat
2.5 inch exhaust piping
Skunk2 chipped P28
[Modified by MaliceGSR, 8:43 PM 5/4/2002]
Old May 4, 2002 | 10:48 PM
Type-ARR's Avatar
Default Re: C.R. B16A2 head on B18c1 bottom end? (MaliceGSR)
ITR intake manifold
B16 pistons
ITR tranny
Mugen head gasket
5zigen header
Carsound cat
Skunk2 chipped P28
if your compression is like 10.6:1 or anyhting above 10.5 you should break 200 whp with good tunning
Old May 5, 2002 | 07:30 AM
Malice's Avatar
New User
Default Re: C.R. B16A2 head on B18c1 bottom end? (TurboR481)
compression should be at 11.4:1 when this is all done!
Old May 7, 2002 | 11:25 AM
g's integ's Avatar
What do you think?
- b16b (CTR)head
- b18c bottom
- CTR pistons
- GS-R cams (will up upgrade to CTR or ITR cams soon)
probenator
Oct 12, 2006 02:33 PM
Nikos
Jul 2, 2003 08:59 AM
3rdGteg
Sep 24, 2002 07:58 PM
SleeperCreeper
Apr 3, 2002 12:05 AM
SiBirdie
Oct 12, 2001 05:58 PM
