Will a 94h22 v-tech head work with 01h22 block
Old Aug 28, 2006 | 07:10 AM
x-1's Avatar
x-1
Default Will a 94h22 v-tech head work with 01h22 block
My timing belt just went on my 92 hatch h22 turbo, so my valves are bent.
The motor that's in the car is 01 and the head that i got is a 94. So, will it work?
Thanks
Old Aug 28, 2006 | 07:47 AM
petern101's Avatar
Default Re: Will a 94h22 v-tech head work with 01h22 block (x-1)
yeah just get the right head gasket and you might need to change the distributor / injectors
you can do a search on how to do those and look up closed deck vs open deck
Old Aug 28, 2006 | 09:28 AM
x-1's Avatar
x-1
Default Re: Will a 94h22 v-tech head work with 01h22 block (petern101)
When i did the swap i converted it to 0bd1.
So, what head gasket do i need to get?
Old Aug 28, 2006 | 09:33 AM
2lude4u's Avatar
You need a head gasket meant for the 01 open deck block.
Old Aug 28, 2006 | 09:36 AM
petern101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">
you can do a search on how to do those and look up closed deck vs open deck</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x-1 &raquo;</TD></TR><TR><TD CLASS="quote">
So, what head gasket do i need to get?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u &raquo;</TD></TR><TR><TD CLASS="quote">You need a head gasket meant for the 01 open deck block.</TD></TR></TABLE>
you got lucky
Old Aug 28, 2006 | 09:47 AM
x-1's Avatar
x-1
Default Re: Will a 94h22 v-tech head work with 01h22 block (2lude4u)
thank you
Old Aug 28, 2006 | 09:51 AM
x-1's Avatar
x-1
i know
VVV
Jul 30, 2007 03:37 PM
junior40er
37
Jun 8, 2006 07:01 AM
greasemonkee
Oct 13, 2005 10:57 AM
evilone
Dec 22, 2004 02:37 AM
evilone
Dec 21, 2004 03:34 PM
