Elemental Designs 6.5" Midbass?
Are you looking at these
eD eDi 6500s System ?
It tells you teh power handling is 150, not sure if that's rms or peak. From the looks it might be rms power. If it's rms it would ble 150 per speaker total.
And if it says it's a 4ohm, then it's a 4ohm speaker, I believe they are svc not dvc. So what they say is what u can run them at (someone correct me if I'm wrong). Eclipse, Focal, CDT, Diamond Audio, Resonant Engineering XXX6.5, I like these companys.
there was a big stink about these all over the web a while back. everyone who had them loved them. they MUST be properly setup to achieve good sound and bass. they are subwoofers though not midbass. you cant just put them in a door and expect good results. check to see if they are free air compatible. if they are you could dynamat the whole door and it should work well.
