what electronic vss will work on my si tranny w/jdm cluster?
Old Aug 27, 2006 | 06:42 PM
TheGreatBamDeanO's Avatar
Default what electronic vss will work on my si tranny w/jdm cluster?
i tried using a b series electronic vss but it wouldnt fit. just recently swapped out engine for a sohc vtec and accidentally broke the one i had in it; was made of plastic. im not sure which vss i had. so could a vss from a 92-95 d series? not popping any codes.. so any help would help!
Old Aug 28, 2006 | 01:10 AM
Cheeech's Avatar
Default Re: what electronic vss will work on my si tranny w/jdm cluster? (TheGreatBamDeanO)
I would like to know too, since im the one that broke it
Old Aug 28, 2006 | 01:15 AM
salman's Avatar
All from B series will fit in,
Old Aug 28, 2006 | 02:20 AM
philkehn's Avatar
take a look at the serial number on the front of the tranny.. should say y1, l1, s1... etc, do a little research on what the engine the tranny is from or model of the rex the tranny is from and just pick the sensor off another tranny of the same sort
Old Aug 28, 2006 | 03:07 AM
Cheeech's Avatar
Default Re: (salman)
I apologize, we were not specific enough. He has a JDM d15b with a crx si cable tranny. The electronic vss he had on his car was broken during the swap....and we are in need of another one but are not sure what make n model to ask for, we tried using a b series electronic vss but it did not fit correctly. any help would be much appreciated.
Old Aug 28, 2006 | 07:24 AM
salman's Avatar
OOOh its a D15B,
I dont know about that, butmostly they fit
Old Aug 28, 2006 | 07:45 AM
Loserkidwac's Avatar
I think 92-95 should work for you, I think i have a busted one I could send you if you wanted to try it out but you might as well just buy a good one instead of paying shipping just to test fit but let me know
ask mista bone he'll know
Old Aug 28, 2006 | 07:51 AM
v4lu3s's Avatar
RTFM
i put a vss from a 92 civic into an 88 crx si tranny and it worked though i had to mode something to make it all fit, not wiring mod, but a little bt of cutting and grinding.
Old Aug 28, 2006 | 01:14 PM
Cheeech's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">i put a vss from a 92 civic into an 88 crx si tranny and it worked though i had to mode something to make it all fit, not wiring mod, but a little bt of cutting and grinding.</TD></TR></TABLE>
Thanks, Ill see if i can find one from a 92+ civic...
Old Dec 18, 2006 | 06:55 PM
ONEFASTJDM's Avatar
Default Re: (Cheeech)
did it work?
GOTNOS
Feb 9, 2004 08:44 AM
EF-9SiR
Sep 27, 2002 10:02 PM
