Removing VAFC2
Old Aug 27, 2006 | 01:44 PM
w0ng_sta's Avatar
Default Removing VAFC2
Hey so i just boosted my car and got a hondata s200 instead of continuing to use my vafc2. The hondata is all set up but Ive been told that I have to remove my VAFC2. Anyone know how? cuz i was going to just cut out the wires to the vafc2 but someone said that was a bad idea =[
Old Aug 27, 2006 | 10:10 PM
JDMister_EF9's Avatar
Default Re: Removing VAFC2 (w0ng_sta)
Just cut the VAFC wires from the harness. You'll loose about 1/2 of a cm, but that's nothing compared to the time that you'll be wasting if the wires have been soldered on.
Old Aug 27, 2006 | 10:30 PM
98vtec's Avatar
moderator emeritus
i believe after you remove the vafc, you will need to rewire two factory wires back together. I know one of them is the vtec signal but i cant remember the other.
Old Aug 27, 2006 | 11:21 PM
ls-vtec-crx's Avatar
You shouldn't have any problem with the two wires if you already have the s200 installed properly!
Old Sep 7, 2006 | 09:58 AM
w0ng_sta's Avatar
Default Re: (ls-vtec-crx)
?? once the ecu is chipped .. dont u just plug it in? what do the wires have to do with the s200 directly?
Old Sep 7, 2006 | 10:17 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls-vtec-crx &raquo;</TD></TR><TR><TD CLASS="quote">You shouldn't have any problem with the two wires if you already have the s200 installed properly!</TD></TR></TABLE>
s200 is not a replacement. You will still have to resolder the two wires back together. If you dont, you will not get a vtec signal, thus the ecu will not sense the vtec crossover and the motor will not run right.
djgruesome
Jul 3, 2006 01:37 AM
ludermark
Jan 30, 2005 04:57 PM
rs
Sep 22, 2003 07:50 PM
CPR
Aug 30, 2002 06:40 AM
Joe01PYITR
Jun 25, 2002 11:12 PM
