major oil leak HELP
Old Aug 27, 2006 | 12:23 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default !!!!!!!!!!!!!major oil leak HELP!!!!!!!!!!!!!!!!!!!!!
i just put the head back on my block (b16a) (new valve seals, valves and cleaned), but now there is a major oil leak coming from the block. i changed the oil and put a new oil filter check the gasket and put new one on. there is still an oil leak that i cant figure out where it is coming from. I looks like it is coming from the pcv box on the back of the block.
need suggestions on were oil is coming from.
and yes i have search most were just oil filter and oil pan. Engine is leakiing like a quart in like 10 cranks from the engine.
Engine is a ("B16")
thanks
JustCant5topMe
Aug 16, 2013 12:18 PM
mrspeedy69
14
Feb 5, 2012 11:48 AM
climb_on
Sep 30, 2007 06:48 PM
92redhatch
Aug 27, 2006 09:52 AM
92accordEX4life
Jan 17, 2006 05:30 PM
