Having shifting problems
Old Aug 27, 2006 | 01:46 AM
Greasemonkeyracing007's Avatar
Default Having shifting problems
GOt a quick question, when i shift my CRX from 1st to 2nd and 2nd to 3rd , it grinds when i shift, and when i down shift , if i shift slowly, it wont grind, other way around with the downshift,
i think i have low tranny fluid, might this be IT???
i usually shift slowly because im scared that if i keep grinding it will break something, what do you guys think,
i press the clutch down all the way everytime i shift, and it still does it, when i shift slowly, it will not grind,
might have to do with the RPMS? it will defenetelly grind when i shift at HIGH RPMS
let me kow what you guys think, i got school soon, too soon, and want to fix before that, thanks, GreaseMonkey007
Old Aug 27, 2006 | 02:12 AM
Suck my DX's Avatar
Default Re: Having shifting problems (Greasemonkeyracing007)
well if you think its low on tranny fluid,why dont you check it? for all you know its never been changed and dirty as hell...
if the fluid is good,go for that synchromesh stuff...thats like a 50/50 chance...it fixes some peoples grinds and doesnt do anything for others...
pretty much its just the synchros wearing down due to age and misuse...if ur a D guy your better off finding a new one,but if your a B guy its definitely worth it to swap out the synchros with new ones...its not a difficult job if you know what you are doing...i suggest that you buy a helms manual and read as much about your car as possible
Old Aug 29, 2006 | 10:18 PM
im a check my fluid, or might as well change it , why not,
dont have the money to change the transmission yet, so that will have to wait, ill try the oil first,
thanks bro
Old Aug 29, 2006 | 10:32 PM
salman's Avatar
yep, let us know after chaning the oil, what happen , Hopefully ull find positive result,
Nornally if some thing is broken or damege, changing oil will not help,
Ill not change any thing,
avargas28
Aug 2, 2011 04:19 PM
Lithel
Jan 18, 2008 12:25 PM
S2kGuy07
Honda S2000
May 2, 2007 06:07 AM
91(si)hatchey
Sep 6, 2006 08:57 AM
sohc prelude
Feb 26, 2006 07:26 PM
