Blown head gasket or no?
Old Aug 27, 2006 | 01:07 AM
racingfan's Avatar
Default Blown head gasket or no?
so I dropped off my car down at a local shop have them replace my head gasket, but one of the guy works there told me today said it might not be the head gasket problem, coz when you have a blown head gasket the car should smoking all the time, but my car only smoke when Its on throttle, he said it could be the gasket inside of the turbo is leaking or blown, that mades me really worry..
what you think it could be? the car is running fine in the start up and idel, BUT once you rev it up to about 4k it start white smoking.. WFT?
Old Aug 27, 2006 | 04:02 AM
Danny_EJ's Avatar
could be a cracked sleeve, or if aftermarket couldbe sunken. You need to take of the head..
Does the turbo have water lines going to it? if not, it wont blow white smoke.
Old Aug 27, 2006 | 01:46 PM
racingfan's Avatar
Default Re: (teggydesign)
anyone else??
Old Aug 27, 2006 | 03:54 PM
NJIN BUILDR's Avatar
If you have oil in the coolant it's not getting there through the turbo.Head gasket or sleeve.A coolant system pressure test would tell you pretty quick.
Old Aug 29, 2006 | 02:24 PM
racingfan's Avatar
Default Re: Blown head gasket or no? (teggydesign)
up...
Old Aug 30, 2006 | 10:14 PM
racingfan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danny_EJ &raquo;</TD></TR><TR><TD CLASS="quote">could be a cracked sleeve, or if aftermarket couldbe sunken. You need to take of the head..
Does the turbo have water lines going to it? if not, it wont blow white smoke.</TD></TR></TABLE>
yeah, it has water line going to the turbo.
Old Sep 2, 2006 | 12:41 AM
racingfan's Avatar
up.. still need some help
Old Sep 2, 2006 | 01:43 AM
bokals's Avatar
if it was a blown gasket you would have white smoke and it would smell really sweet
Old Sep 3, 2006 | 11:27 AM
racingfan's Avatar
Default Re: Blown head gasket or no? (Element.)
it does has white smoke
oakraidersnum1
Mar 9, 2008 01:53 PM
Adrian69
May 8, 2005 05:05 PM
sleepyIntegra
May 24, 2004 11:14 AM
redcivic
Apr 22, 2003 03:54 PM
sagaprelude
Nov 10, 2001 02:46 PM
