Need More Power...??
i have a 94 jdm h22a and was looking to do a few more little things before i put it away for the winter the fallowing are done already
Enjo Engine Mounts
Lightened Crank Pully
Fuel Pressure Regulator
Short Shifter
AEM Cam Gears
Cat Back Exaust
Intake
Great Tires
What should i b getting next
thxs james
Enjo Engine Mounts
Short Shifter
AEM Cam Gears
Cat Back Exaust
Intake
Great Tires
thxs james
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamesconnor87 »</TD></TR><TR><TD CLASS="quote">i heard that a header does next to nothing on these engines ?</TD></TR></TABLE>
You're half right. Cheap headers do next to nothing. Good headers, like RMF, can gain up to 15whp with good tuning
what is a better intake manifold Skunk2 or edelbrock? and would a throttlebody and intake manifold help me to get power at this stage of my build with this engine?
I say get a good header, high-flow cat, 8lb flywheel, some lightweight wheels and a good suspension setup.......to start with.
well,
100 on stock internal is very doable, just needs a lot of tuning and probably some ignition work. Since a VAFC will most likely not be enough, i would go with crome or hondata, in which case the p13 wont work and you will need a p28 or p72......
now i have no idea how honda computers work. is crome or hondata a chip or an engine management system? and im asuming p28 or p72 is the ecu itself. and when you say tuning are you taking about air/fuel ratios and ignition timing. the only place where i live that i know of tunes is a muscle shop, i talked to a guy that had his silvia tuned there and he said all they would do is air/fuel.....im lost, but i want nitrous.
36Chitownrunnin
13
Aug 7, 2008 09:46 PM
