scraping noise?
Old Aug 26, 2006 | 10:11 PM
hondafrk505's Avatar
Default scraping noise?
well today my friend and i went to go drive around, then we saw this "track" and we decided to go do a couple of laps... well i let my friend drive it once because i trusted him.. so there was this hard left corner, and he went about 50-60 miles and i was like wtf.. anyways after we left, i dropped him him off and then turned around to go home.. but when i turned around (left) i heard this scraping noise.. i thought to myself no biggie.. so then i take the next left and then it gets worse. so i stopped at a gas station and checked everything out.. the suspension is fine because i would hear a clicking noise and it would be loose.. so after 30 minutes of hard searching, i find nothing.. so i go home and check everything out again.. still NOTHING. so now everytime i turn left u hear this wierd scraping noise and it annoys the expletive outta me.. so what do u guys think the problem is?? and if it is a problem, would aftermarket warrenty cover this?
thanks
Daniel
Old Aug 26, 2006 | 10:16 PM
oh and when i turn right, its totally fine.
Old Aug 27, 2006 | 02:15 AM
eMpAtHy's Avatar
Default Re: (hondafrk505)
bring it into the dealership. should be covered under warranty and let them figure out what it is.
Old Aug 27, 2006 | 02:41 AM
Miracle's Avatar
Default Re: (eMpAtHy)
Probably a wheel bearing I would think of first. But I dont know.
Old Aug 30, 2006 | 05:21 PM
CASTUDILLO01's Avatar
Default Re: scraping noise? (hondafrk505)
CHECK OUT YOY SPRING. SEE IF YOUR SPRING IS SEATED PRPERLY TO THE BASE OF THE STRUT. THAT WILL MAKE A NOISE COMMON ON RSX. THERE IS A SERVICE BULLETIN ON THAT. ALSO CHECK TO SEE THAT THE SPLASH SHEILD AROUND THE ROTOR IS NOT RUBBING. JUST GO TO THE SIDE IT MAKES NOISE AND FROM UNDER THE CAR PULL THE SPLASH SEILD BACK FROM THE BOTTOM. THAT WILL MAKE A SCRAPPING NOISE IN TURNS.
gators113
Transmission & Drivetrain
Jun 24, 2019 02:51 PM
lken767
Honda CR-V & Element
Nov 1, 2015 09:23 PM
typeee
Nov 21, 2003 01:05 PM
Gen5_EG
Nov 10, 2001 09:05 AM
