wideband work at secondary...?
Old Aug 26, 2006 | 06:01 PM
digitalcongo's Avatar
Default wideband work at secondary...?
i'm looking to start testing my wideband naturally aspirated to get the hang of it
i'm running a mini-me with a bunged up secondary obd1
y8 head on a b7 block...somewhere just over 10:1 compression
i figured it would save me some wiring in the narrowband feed for the ecu...
if i can just run the wideband in the secondary
will it reach normal operating temp at the cat behind the header...???
thanx
Old Aug 26, 2006 | 06:18 PM
Default Re: wideband work at secondary...? (digitalcongo)
i found my answer by searching
thank you h-t
raverx3m
Jan 5, 2014 05:12 PM
1kleenef
Nov 2, 2008 09:37 AM
1SlowSi
Jan 31, 2005 09:13 PM
Brian Hinson
Dec 2, 2004 07:31 PM
91civicEX
Jun 9, 2003 04:32 PM
