Door mounted seat belt swap? Any info?
Old Aug 26, 2006 | 10:06 AM
Nose's Avatar
Default Door to B-pillar mounted seat belt swap? Any info?
Anyone know what the secrets are for changing my 90 CRX to 88 model doors, then moving the belts to the B-pillar? Anybody got any ideas on that?
Thanks in advance. :-)
Modified by Nose at 1:39 PM 8/26/2006
Old Aug 26, 2006 | 10:28 AM
bagpipe goatee's Avatar
there's some nice websites on it. but basically, you have to weld a nut or two per side at the prepunched holes to hold the pillar seatbelts on, and then you have to change the wiring plugs on the doors so you still have speakers.
not hard if you have access to a welder.
Old Aug 26, 2006 | 10:50 AM
Nose's Avatar
Default Re: (bagpipe goatee)
Cool...you wouldn't happen to know which websites are out there, would ya? Did a coupla searches, couldn't find anything here or elsewhere yet. Off topic, I don't think this site's search engine is running on all four cylinders, can't seem to find much with it. :-)
Old Aug 26, 2006 | 10:55 AM
Zaakro's Avatar
Default Re: (Nose)
umm here
https://honda-tech.com/zerothread?id=1456104
oh and that took me like 5 seconds to find.
now i understand why people bitch about searching
Old Aug 26, 2006 | 11:04 AM
Nose's Avatar
Default Re: (Zaakro)
OK fine, blame it on the new guy.
FWIW, I just did another search, came up with the following:
"No Results Found"
Besides, why should anyone do their own work when we can just lazily post our inquiry here? (that's sarcasm, of course)...
Seriously...thanks for the link, that looks like a particularly good write-up. :-)
Old Dec 17, 2006 | 08:43 AM
kcjohnnyboy's Avatar
Default Re: (Nose)
i just did this conversion this week but i'm having problems. i got everything swapped over to the 88 doors but then everytime i brake, the door ajar, the seat belt light on the cluster, both light up with the beeping.
if anyone done this already please chime in and see what is wrong?
Old Dec 17, 2006 | 11:42 AM
turbocrixhf's Avatar
Default Re: (kcjohnnyboy)
check wiring there could be a bare wire rubbing somewhere or short cuircuting when the weight shifts from back to front from the brakes being applied.
Old Dec 17, 2006 | 11:47 AM
model x's Avatar
I'm not sure if it makes any difference but the door jam where the striker plate is, is different. On the models with the seatbelt doors the striker is a few mm closer to the door than the models with the seatbelts in the b pillar.
I put 88 doors in my 90 and the door just barely hits the door jam above the striker
Now I'm using 90 doors that have the seat belts but I'm removing all the seat belt stuff and using what I welded into the b pillar.
Old Dec 17, 2006 | 03:24 PM
Default Re: (model x)
i will try to take a look at the door jam piece and modify it to work
Old Dec 17, 2006 | 05:44 PM
CRX 2.0V-T's Avatar
okay so every1 trying to convert to 88 door. Any1 know what's the different that make 88 door lighter then 90?
Old Dec 17, 2006 | 05:51 PM
synergy10's Avatar
Default Re: (Lak of Speed)
I'm thinking the difference in weight would be the seat belt mechanism.
Old Dec 17, 2006 | 06:11 PM
CRX 2.0V-T's Avatar
Default Re: (synergy10)
If it's the seat belt that makes the different then just get racing harness, lighter than 88 and simple plus no need to go all the troubles. LOl
Old Dec 17, 2006 | 06:16 PM
synergy10's Avatar
Then you'll need to get a roll bar to bolt the harnesses to. What if you don't want/need a roll bar? Everyone has their reasons why they would do this.
Old Dec 17, 2006 | 06:18 PM
synergy10's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">umm here
now i understand why people bitch about searching</TD></TR></TABLE>
I don't think this guy done it for weight savings...
Old Dec 17, 2006 | 07:19 PM
E_F_9's Avatar
The doors are lighter because of not having side impact beams
Old Dec 18, 2006 | 01:35 PM
model x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lak of Speed &raquo;</TD></TR><TR><TD CLASS="quote">If it's the seat belt that makes the different then just get racing harness, lighter than 88 and simple plus no need to go all the troubles. LOl</TD></TR></TABLE>
Racing harnesses are a super PITA. You can't reach anything(radio, HVAC controls) when you have them on.
crxguy406
Feb 9, 2015 12:59 PM
dragon_lowrider
May 23, 2012 11:08 AM
90 DX Driver
Jan 14, 2009 10:00 AM
mackymcg
Oct 26, 2002 06:15 PM
