CEL codes, don't know how to fix them
Old Aug 25, 2006 | 08:30 PM
MadCityLude
Guest
Posts: n/a
Default CEL codes, don't know how to fix them
I am throwing 2 codes #5 and #41
#5 is MAP - in the service manual it says that it is some kind of vaccum problem, I can't find any problems. What are some common problems and fixes for this code.
#41 is O2 sensor - this one I know, but a little confused about. Its not hooked up, the reason being I can't find the plug for it. I just recently switched from an F22 harness running my H22 to an H23 auto harness, cause the F22 was a hack job. Before I had a fairly long plug that reached down to the downpipe under the intermediate shaft (or in that general area). Now I find no plugs like that at all. How is the H23's setup?
Old Aug 26, 2006 | 06:53 AM
MadCityLude
Guest
Posts: n/a
Default Re: CEL codes, don't know how to fix them (MadCityLude)
BUMP:
Old Aug 26, 2006 | 07:06 AM
AnthonyG2003
Guest
Posts: n/a
Isn't CEL #1 a o2 sensor code?
Old Aug 26, 2006 | 07:21 AM
MadCityLude
Guest
Posts: n/a
Default Re: CEL codes, don't know how to fix them (AnthonyG2003)
this is where I got my info,
http://www.92lude.com/diagnose_error_codes.htm
Old Aug 26, 2006 | 08:09 AM
AnthonyG2003
Guest
Posts: n/a
41 is the O2sensor heater...
1 is the O2sensor
Old Aug 26, 2006 | 08:16 AM
prelude1897's Avatar
might wanna keep searching for the O2 sensor plug, cause then that'll get rid of your codes....I was throwing 3 codes when I did my motor swap to my 00 Prelude, and come to find out, I forgot to plug up my O2 sensor. Once I did that, all the codes cleared and haven't come back
Old Aug 26, 2006 | 09:16 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: CEL codes, don't know how to fix them (prelude1897)
would it be easier/cheaper to plug the o2 sensor instead of buying a new one?
Old Aug 26, 2006 | 08:09 PM
MadCityLude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">41 is the O2sensor heater...
1 is the O2sensor</TD></TR></TABLE>
what is the difference?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">might wanna keep searching for the O2 sensor plug, cause then that'll get rid of your codes....I was throwing 3 codes when I did my motor swap to my 00 Prelude, and come to find out, I forgot to plug up my O2 sensor. Once I did that, all the codes cleared and haven't come back</TD></TR></TABLE>
I think I found the plug, but it is a female ended plug, and my O2 sensor is also female.
mike_paz17
Jun 14, 2007 07:50 PM
TheHooded_Mike
22
Apr 19, 2007 04:57 PM
killaj12
Mar 5, 2007 04:16 AM
LsPower
Dec 3, 2002 08:56 AM
