hydro carbons
Most common cause of over fueling is a bad O2 sensor... although those are expensive...
Depending on how close to the threshold of the limit you are you might be able to just get away with cap/rotor/plugs... that way it's burning everything a little better.
You CAN get it to pass just by messing with the timing but you have to be able to test it on a sniffer... and tune it to appease the machine... then set it back to normal.
the issue isnt too much fuel going into the engine, the problem is that there is not a complete burn...the fuel regulator or 02 wont fix it...depending on how much you are over a simple tune-up could solve the problem.
i agree. Start off by doing a complete tune up (hotter plugs). I would also suggest throwing in "heat" or "Lucas" fuel additive. Pour it into 3/4 to full tank. Wait until you have to refill your gas again...then go and take it through emissions/smog test. You DO NOT want to take it through the test with the fuel additives in.
