A little exhaust help please-
Old Aug 25, 2006 | 05:50 PM
mini-e's Avatar
Default A little exhaust help please-
I am doing a budget modest goal (125-130 whp)mini me swap on a 96 ek hatch and i am starting in on the cali dx exhaust which has the cat right up on the motor. so i have a nearly new 98 ex header, and from what i have searched up a 96-00 ex- or 99-00si cat will do the trick. what i am wondering and could not find when i searched was:
is the ex and si cat back ehxuast the same dia?
can one easily mod the sedan cat back to fit the hatch?
thx-
Modified by mini-e at 12:31 PM 8/26/2006
Old Aug 26, 2006 | 10:02 AM
mini-e's Avatar
Default Re: A little exhaust help please- (mini-e)
super technical questions for sure, but if anyone know i would appreciate the help.
Old Aug 26, 2006 | 10:13 AM
NonovUrbizniz's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-e &raquo;</TD></TR><TR><TD CLASS="quote">I am doing a budget modest goal (125-130 whp)mini me swap on a ek hatch and i am starting in on the cali dx exhaust which has the cat right up on the motor. so i have a nearly new 98 ex header, and from what i have searched up a 96-00 ex- or 99-00si cat will do the trick. what i am wondering and could not find when i searched was:
EX/SI's are the same diameter exhausts.
Sedan exhaust is exactly one cat lenght longer than the coupe... however the coupe/hatchbacks are different... I BELIEVE it CAN work but it's a pita... I think the mid section is basically the same but the bend over the rear LCA is different....
I KNOW for example the magnaflow system for 2/4 door is the same... if you get it for the 2dr you basically get a free test pipe... if you get it for the 4 door you just get a complete exhaust.
But it's an entirely differnt part number for the hatchbacks...
IMO save the pain and get a hatch catback exhaust.
Old Aug 26, 2006 | 11:09 AM
mini-e's Avatar
Default Re: A little exhaust help please- (NonovUrbizniz)
thanks!!!
exactly the info in needed to make a good desicion.
good luck-
Old Aug 26, 2006 | 11:16 AM
GoonieAsian's Avatar
i am doing almost the same thing right now i have an ex header sitting right now and what i have heard is that you can use any cat, and what Apex told me that if i am using ex header and cat, the axle back portion is the same, but the b pipe are different from the ex/hx/si and the dx/lx models. so i am going for the ex ws2 exhaust and have to extend the o2 sensors to make them work with the header/cat combo.
jrzy2nR
18
Nov 10, 2008 06:23 PM
Hatch It
Sep 23, 2005 11:12 PM
lizardtea
Jan 13, 2005 08:12 AM
Greg123
27
Dec 29, 2003 02:46 PM
RickChew
Feb 17, 2003 12:03 PM
