Changed oil and....NOTHING...help wanted
Old Aug 25, 2006 | 01:28 PM
AsSanitySlipsAway's Avatar
Default Changed oil and....NOTHING...help wanted
Whats up everybody this may sound dumb but i just changed my oil (b18) put on a new filter and all that..i go to start my car and...NOTHING..no lights, no turn, no clicks...nothing. So i have a jump box thinking its my battery, NOTHING...now when i removed the oil fiter oil did leak in some places, my question what is below that could cause my car not to start, everything ran fine until now...i guess oil got into somewhere it shouldnt have? could i have shorted something somwhere?? i know the possibilities are probably endless as to why it wont start, but im confused...this has never happend before...any opinions would be greatly appreciated, thanks.
Old Aug 25, 2006 | 01:30 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Changed oil and....NOTHING...help wanted (AsSanitySlipsAway)
That's really fucked up. Did you check your battery to make sure nothing became loose? There's nothing under the filter that will keep the car from starting if it becomes soaked with oil, so that's not the problem.
Old Aug 25, 2006 | 01:33 PM
yeah i checked bat. connections, everything is fine...lol...its just weird if you ask me i go to turn the car over and im left with a blank face...kinda like...uhhhh??
Old Aug 25, 2006 | 01:34 PM
Hater's Avatar
What else did you do?
Check battery terminals, check underdash and underhood fuses.
Old Aug 25, 2006 | 01:36 PM
All the fuses look fine, i looked over those as well...this may be a dumb question, im new to hondas, but do they have a kill switch anywhere i might of hit?
Old Aug 25, 2006 | 01:44 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (AsSanitySlipsAway)
I've never heard of a killswitch..
But word check and make sure your battery cables are on tight. Just to be sure take them all the way off and put the back on securely. That's the only thing I can think of.
Old Aug 25, 2006 | 01:50 PM
EGwhat!!!'s Avatar
Default Re: (ek forever guy)
check all you connections you probably loosened on up while trying to remove the oil filter
Old Aug 25, 2006 | 01:52 PM
KtHaNxBai's Avatar
Default Re: (EGwhat!!!)
grounds?
Old Aug 25, 2006 | 01:54 PM
ek4_b16a's Avatar
Default Re: (galaxykid70)
^^Grounds...check them...wouldn't know which one you would've hit...but check your grounds...
Old Aug 25, 2006 | 02:41 PM
so i checked my connections, and grounds, everything seems to be as it was...would oil in my alternator cause this?? i removed the oil filter from on top of the car ..
Old Aug 25, 2006 | 02:46 PM
i get no lights from the interior, no headlights, no radio, no anything..
Old Aug 25, 2006 | 04:15 PM
Hater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AsSanitySlipsAway &raquo;</TD></TR><TR><TD CLASS="quote">i get no lights from the interior, no headlights, no radio, no anything..</TD></TR></TABLE>
Try jumping the battery and seeing if, by chance, you somehow totally fried a battery completely? By this I mean just jump the cables, and turn something electrical on, don't try starting it.
Old Aug 25, 2006 | 04:21 PM
Syndacate's Avatar
It's a ground some place...only a battery ground can cause the problems ur having (absolutely no power what-so-ever, even on a boosted battery) - definately a ground...not even the main relay would caust this b/c you'd at leas thave headlights for a bit if ur main relay was bad...check all ur battery grounds (one coms off the + terminal I believe)...it's definately one of them...
Oil in the alternator probably wouldn't do it..but that's not the reason, even if u *** fucked your alternator you'd be able to crank it over and run for a few minuts b4 the battery drained and died...
Old Aug 25, 2006 | 05:42 PM
0618turbocivic's Avatar
did you knock something off sensor anything while changing the filter? check all grounds
Old Aug 25, 2006 | 07:14 PM
SOHCejcivic's Avatar
Default Re: Changed oil and....NOTHING...help wanted (0618turbocivic)
if nothing is coming on, you aren't getting power...period. so it's at the battery. check your terminals...again obviously. jiggle them...take them off and re-position them and tighten them down again. mine stay tight, but they're kinda fucked up and don't make a great connection sometimes.
there is nothing you could've leaked oil onto to short anything out. the only thing electrical around the filter is the oil pressure switch (only makes your light pop on when you don't have pressure)
Old Aug 26, 2006 | 01:09 AM
Default Re: Changed oil and....NOTHING...help wanted (SOHCejcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic &raquo;</TD></TR><TR><TD CLASS="quote">
there is nothing you could've leaked oil onto to short anything out. the only thing electrical around the filter is the oil pressure switch (only makes your light pop on when you don't have pressure)</TD></TR></TABLE>
Thats good to know
so i went back after an hour or two and re-checked all my fuses..all of you were right my ''battery'' fuse under the hood was blown(80A). I didnt see it the first, or second time. Guess i just needed to count to ten, that or new glasses. But none the less not a bad thing, all my grounds and connects are fine! thanks again for all the replies.
Old Aug 26, 2006 | 01:18 AM
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Oil in the alternator probably wouldn't do it..but that's not the reason, even if u *** fucked your alternator you'd be able to crank it over and run for a few minuts b4 the battery drained and died...</TD></TR></TABLE>
Thats also good to know
Old Aug 26, 2006 | 01:56 AM
DaKINE-Ek's Avatar
From: So Cal where old pople try to race you, U.S.A
Thats good to know
so i went back after an hour or two and re-checked all my fuses..all of you were right my ''battery'' fuse under the hood was blown(80A). I didnt see it the first, or second time. Guess i just needed to count to ten, that or new glasses. But none the less not a bad thing, all my grounds and connects are fine! thanks again for all the replies. </TD></TR></TABLE>
same thing went bad in mine when i swapped i was goin to suggest it but you got to it before i could respond
briq4
Honda Civic (2001 - 2005)
11
Aug 17, 2009 04:30 PM
HondaEJ7
Feb 13, 2006 05:18 PM
a1320honda
24
Jun 21, 2004 01:17 PM
00bluesi
May 23, 2004 07:31 PM
jaydm98
12
Nov 2, 2003 01:44 PM
