Spark plug wires, distributor cap, rotor
Old Aug 25, 2006 | 11:12 AM
TSAngry's Avatar
Default Spark plug wires, distributor cap, rotor
I have about 60k miles on my gsr. I was just wondering how often everyone changes their spark plug wires, distributor cap, and rotor. Do you think its necessary to replace at 60k?
Old Aug 25, 2006 | 12:26 PM
95 integra's Avatar
Default Re: Spark plug wires, distributor cap, rotor (TSAngry)
I would change the cap/rotor but the plug wires should be just fine. The rotor generally looks pretty burnt up after about 30k of use.
Old Aug 25, 2006 | 12:30 PM
unknown0001's Avatar
Default Re: Spark plug wires, distributor cap, rotor (95 integra)
You can use an ITR rotor I belive...it's a bit stronger then the regular one that you purchase for the LS/GSR
Old Aug 25, 2006 | 12:41 PM
95 integra's Avatar
Default Re: Spark plug wires, distributor cap, rotor (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">You can use an ITR rotor I belive...it's a bit stronger then the regular one that you purchase for the LS/GSR </TD></TR></TABLE>
The older GSR has been superseded by the ITR....thus if you go to honda and order one for the GSR you get the ITR one. Also the back cover is a little different but that will come with it.
Old Aug 25, 2006 | 12:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">
The older GSR has been superseded by the ITR....thus if you go to honda and order one for the GSR you get the ITR one. Also the back cover is a little different but that will come with it.</TD></TR></TABLE>
ah, never knew that
Old Aug 25, 2006 | 12:49 PM
orangebarius's Avatar
its a good idea to replace your pcv valve and fuel filter at 60k too.
my tune up schedule:
rotor, cap, plugs, fuel filter every 30k
wires every 60k.
thats just what i do. many people do it differently.
Old Aug 25, 2006 | 02:08 PM
95 integra's Avatar
ah, never knew that </TD></TR></TABLE>
Yea, it still shows the P72 part #, but if you actually order it, you should get a P73 (or atleast i did when i ordered mine and I called to make sure it was the right **** and thats what the guy told me).
Old Aug 25, 2006 | 03:25 PM
TSAngry's Avatar
i've never replaced the pcv valve and fuel filter. how hard is it?
Old Aug 27, 2006 | 03:31 PM
its really easy. they are both right under the hood. the pcv valve is on top of the intake manifold and the fuel filter is on the firewall near the battery.
Old Aug 30, 2006 | 12:08 PM
95TEG's Avatar
Default Re: Spark plug wires, distributor cap, rotor (orangebarius)
Where is a good place to buy the cap and rotor from other than the dealership?
Old Aug 31, 2006 | 07:37 AM
Default Re: Spark plug wires, distributor cap, rotor (95TEG)
any local parts store. auto zone, strauss, pep boys, etc.
philpsu
Jul 17, 2007 05:08 PM
tegon-gsr
May 18, 2003 09:41 AM
Fuster_Cluck
Apr 13, 2003 08:13 PM
