in car laptop?
Old Aug 24, 2006 | 09:13 PM
j-rome's Avatar
Default in car laptop?
I havent done much resurch on this so ya forgive me if some dosne tmake since or im wrong but I have a completly performance stock civic. is their a way i can plug in a laptop into my ecu or something and moniter air/fuel, rpm's, oil temp or whatever the ecu reads... or whatever reads this crap on the laptop?
pretty much is their anything i can buy that I can moniter stuff like that on a laptop in my car? i dont know what it would have to plug into or need or if this is even possible so any info would be helpful. i dont want to adjust just watch that kind of stuff. but adjusting would be cool even though if i could i wouldent most likely as i would kill my car. but ya i just want to moniter that stuff for the heck of it if its even possible.
thanks!!!
Old Aug 24, 2006 | 10:00 PM
95redeg6's Avatar
Default Re: in car laptop? (j-rome)
NO
Old Aug 24, 2006 | 10:04 PM
turbociviccoupe's Avatar
if your car is stock then why do you want it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95redeg6 &raquo;</TD></TR><TR><TD CLASS="quote">NO</TD></TR></TABLE>
yes there is for tuning purposes. its called datalogging...i use it...reasearch bout it
Old Aug 24, 2006 | 10:07 PM
Luserkid's Avatar
Default Re: in car laptop? (turbociviccoupe)
You could log everything but i believe oil temp with a stock ecu. If you run something like EMS or Motec then i believe you could log everything. But these toys are not worth getting for stock cars.
Old Aug 24, 2006 | 10:09 PM
Default Re: in car laptop? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote"> But these toys are not worth getting for stock cars. </TD></TR></TABLE>
couldlnt have said it better
Old Aug 24, 2006 | 10:10 PM
j-rome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">if your car is stock then why do you want it?
yes there is for tuning purposes. its called datalogging...i use it...reasearch bout it</TD></TR></TABLE>
because i was just givin a nice 1 year old laptop from my brother and dont have anything to do with it so i thought if i could do something like this i might as well...
Old Aug 24, 2006 | 10:11 PM
best thing to do with it is download music and go on honda-tech...
Old Aug 24, 2006 | 10:13 PM
j-rome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You could log everything but i believe oil temp with a stock ecu. If you run something like EMS or Motec then i believe you could log everything. But these toys are not worth getting for stock cars. </TD></TR></TABLE>
so i can or cant "log" everything with my stock ECU? I pretty much just want to do it for fun. but if i have to buy some major things then i wont. i figured if its a few cables and a program why not?
Old Aug 24, 2006 | 10:14 PM
slodel's Avatar
your gay
Old Aug 24, 2006 | 10:15 PM
j-rome's Avatar
Default Re: in car laptop? (slodel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel &raquo;</TD></TR><TR><TD CLASS="quote">your gay </TD></TR></TABLE>
thanks so are you
Old Aug 24, 2006 | 10:17 PM
j-rome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">best thing to do with it is download music and go on honda-tech... </TD></TR></TABLE>
when idiots post that it makes me not want to... so i need to find other things too.
Old Aug 24, 2006 | 10:18 PM
Luserkid's Avatar
You could log the following with a chipped ecu and right connector for logging along with some datalog program:
Water Temp
IAT
TPS
MAP
Injector Duty
o2 (provided you have a wideband)
Speed
What gear your in
ignition
knock
RPM
theres some other little things here and there but thats all i remember right now.
Old Aug 24, 2006 | 10:20 PM
j-rome's Avatar
does it have to be chipped? mine is completly stock and dont want to screw with it to much.
what i want to know is... 100% STOCK 98 civic ex. stock ecu. is it possible to hook up my laptop to it without modifing the ecu?. if so what do i need? or what would i need to do to the STOCK ECU to make it work?
Old Aug 24, 2006 | 10:22 PM
BoosteD16's Avatar
I log these too, with a nokia data cable and an OBDI ecu, it doesn't matter...
Old Aug 24, 2006 | 10:28 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-rome &raquo;</TD></TR><TR><TD CLASS="quote">does it have to be chipped? mine is completly stock and dont want to screw with it to much.
what i want to know is... 100% STOCK 98 civic ex. stock ecu. is it possible to hook up my laptop to it without modifing the ecu?. if so what do i need? or what would i need to do to the STOCK ECU to make it work?</TD></TR></TABLE>
First off you cant log with obd2 (unless you get the LM1 wideband then the datalogger that you could buy with it (give or take 500 - 700 dollars)) cheaper way is buying a chipped ecu and converting to obd1.
Old Aug 24, 2006 | 10:33 PM
j-rome's Avatar
alright. its going to be to much work to be worth doing it on a stock civic. i figured if i could do it with a special cable and program and thats all then i would.
Old Aug 24, 2006 | 10:34 PM
j-rome's Avatar
thanks for all the help guys!!!
ecks_fourttwo
Apr 7, 2005 08:13 PM
richardo
Oct 7, 2004 06:07 AM
RTW DC2R
Sep 6, 2004 12:02 PM
gsr2jdm
Dec 18, 2003 11:23 AM
DC2_Integra
Apr 10, 2003 11:47 AM
