in car laptop?
in car laptop?
I havent done much resurch on this so ya forgive me if some dosne tmake since or im wrong but I have a completly performance stock civic. is their a way i can plug in a laptop into my ecu or something and moniter air/fuel, rpm's, oil temp or whatever the ecu reads... or whatever reads this crap on the laptop?
pretty much is their anything i can buy that I can moniter stuff like that on a laptop in my car? i dont know what it would have to plug into or need or if this is even possible so any info would be helpful. i dont want to adjust just watch that kind of stuff. but adjusting would be cool even though if i could i wouldent most likely as i would kill my car. but ya i just want to moniter that stuff for the heck of it if its even possible.
thanks!!!
thanks!!!
Re: in car laptop? (j-rome)
if your car is stock then why do you want it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95redeg6 »</TD></TR><TR><TD CLASS="quote">NO</TD></TR></TABLE>
yes there is for tuning purposes. its called datalogging...i use it...reasearch bout it
Re: in car laptop? (turbociviccoupe)
You could log everything but i believe oil temp with a stock ecu. If you run something like EMS or Motec then i believe you could log everything. But these toys are not worth getting for stock cars.
Re: in car laptop? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote"> But these toys are not worth getting for stock cars. </TD></TR></TABLE>
couldlnt have said it better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">if your car is stock then why do you want it?
yes there is for tuning purposes. its called datalogging...i use it...reasearch bout it</TD></TR></TABLE>
because i was just givin a nice 1 year old laptop from my brother and dont have anything to do with it so i thought if i could do something like this i might as well...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">You could log everything but i believe oil temp with a stock ecu. If you run something like EMS or Motec then i believe you could log everything. But these toys are not worth getting for stock cars. </TD></TR></TABLE>
so i can or cant "log" everything with my stock ECU? I pretty much just want to do it for fun. but if i have to buy some major things then i wont. i figured if its a few cables and a program why not?
Re: in car laptop? (slodel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel »</TD></TR><TR><TD CLASS="quote">your gay </TD></TR></TABLE>
thanks so are you
thanks so are you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">best thing to do with it is download music and go on honda-tech... </TD></TR></TABLE>
when idiots post that it makes me not want to... so i need to find other things too.
You could log the following with a chipped ecu and right connector for logging along with some datalog program:
Water Temp
IAT
TPS
MAP
Injector Duty
o2 (provided you have a wideband)
Speed
What gear your in
ignition
knock
RPM
theres some other little things here and there but thats all i remember right now.
Water Temp
IAT
TPS
MAP
Injector Duty
Speed
What gear your in
ignition
knock
RPM
does it have to be chipped? mine is completly stock and dont want to screw with it to much.
what i want to know is... 100% STOCK 98 civic ex. stock ecu. is it possible to hook up my laptop to it without modifing the ecu?. if so what do i need? or what would i need to do to the STOCK ECU to make it work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-rome »</TD></TR><TR><TD CLASS="quote">does it have to be chipped? mine is completly stock and dont want to screw with it to much.
what i want to know is... 100% STOCK 98 civic ex. stock ecu. is it possible to hook up my laptop to it without modifing the ecu?. if so what do i need? or what would i need to do to the STOCK ECU to make it work?</TD></TR></TABLE>
First off you cant log with obd2 (unless you get the LM1 wideband then the datalogger that you could buy with it (give or take 500 - 700 dollars)) cheaper way is buying a chipped ecu and converting to obd1.
alright. its going to be to much work to be worth doing it on a stock civic. i figured if i could do it with a special cable and program and thats all then i would.
DC2_Integra
04-10-2003 11:47 AM
