Installing a Harness - why backing plates instead of tapping threaded holes?
Old Apr 26, 2002 | 03:25 PM
norice's Avatar
Default Installing a Harness - why backing plates instead of tapping threaded holes?
I have been looking around the web at a number of harness installs and pretty much all of the installs involve drilling holes and using metal backing plates when attaching bolts to the car.
I was wondering why no one mentioned tapping threaded holes instead. That is how the original bolts are attached to the car - even the ones that must potentially support a lot of force - like the seat and seatbelt anchor points.
Obviously, not all parts of the frame are thick enough to support bolts, but many parts are. Why is this not a common approach?
Old Apr 26, 2002 | 03:53 PM
Austin's Avatar
Default Re: Installing a Harness - why backing plates instead of tapping threaded holes? (norice)
Might want to ask in Competition...they would definately know.
Austin
Old Apr 26, 2002 | 03:54 PM
CRX7's Avatar
Looking at any seat belt mounting points I have found that they are reinforced in comparison to the rest of the sheet metal on the frame. The point you want your harness mounted to is probably not going to be reinforced so you will need backing.
Old Apr 26, 2002 | 05:29 PM
earl's Avatar
Not everyone is smart enough to figure out a good mounting spot from a bad mounting spot. It is much harder to pull the complete backing plate thru the unibody (spreads the force over a larger area) than to pull a nut and bolt thru the body. The rule makes everyone a smart belt installer.
JDMequalslife
25
Apr 28, 2014 12:58 PM
AW
May 11, 2008 01:50 PM
Doctor CorteZ
12
Feb 11, 2003 12:48 PM
KURRRRWA
16
Oct 21, 2002 10:56 PM
ITRacer121
Apr 22, 2002 01:38 PM
