NEED some Help: Radiator cap spring fell
Ive never heard of this happening before.I took the rad. cap off and the spring wasnt connected to the cap.I try to grab the spring and it fell through the side and into the radiator.Opps!
Will this be sucked into the head? or mess with anything?If so will a simple coolant draining from the bottom get it out of there?
Any suggestions?
Thanks
Any suggestions?
Thanks
or squeeeze the coolat tube to try to shoot it back o wher eu can see it thn get t? i dunno...
or
u have one of those magnet anntenna things? use that... good luck.
or
It should just be sitting there inside the radiator, its too large to pass through the radiator, so it will just slide within the top tank. Take the radiator out if you need. It should be a fairly simple process to retrieve it. Also the magnet on a stick is a great idea, so
to that.
to that.
driveslow
Mar 8, 2009 12:22 PM
jose310
Jul 6, 2008 12:05 PM
