p 1509 code can't clear it
Old Aug 24, 2006 | 06:47 PM
tuyoonly's Avatar
Default p 1509 code can't clear it
i have a ls/vtec in a 96 hatch, i'm using stock harness, a friend that i knew did the swap for me and now i have to pass inspection, so i took my obd 1 ecu out and put a stock ecu in i have fixed all the other codes that the ecu had but i can't fix the p1509 code. (manufac vec.spd. idle control auxiliary circuit). i have a vixtor-x intake, 65mm edelbrock trottle body, holley fuel rail and preassure reg. i changed all of these and put si intake, throttle, fuel rail, regulator. but the car doesn't like to stay on when i put these stock parts. i put all my stuff back exept i put stock injectord but i cant seem to be able to clear the p1509 code. any ideas????
i have cleaned and installed 3 diferent iac's nothing yet. is the cable work a little different or what may be my problem???? the car works ok with the obd 1 ecu but when i put the obd2 the car doesn't want to stay on.
Old Aug 24, 2006 | 07:34 PM
saikouEF8's Avatar
Default Re: p 1509 code can't clear it (tuyoonly)
reset the ecu
Old Aug 24, 2006 | 07:37 PM
tuyoonly's Avatar
Default Re: p 1509 code can't clear it (saikouEF8)
how can i do that ?? i use the code reader to clear the codes
Old Aug 24, 2006 | 10:18 PM
saikouEF8's Avatar
did u try pulling the fuse undr the hood for like 30 seconds?
Old Aug 24, 2006 | 10:28 PM
Syndacate's Avatar
Try pulling the backup fuse (7.5amp) under the hood for 10 seconds at least (like saikou said)...
Though I'm confused...I thought the "P" codes came into play on ODB-II engines....why is it coming out on an ODB-I engine :-? Or do the ODB-I engines have P codes too?
Old Aug 26, 2006 | 05:17 AM
tuyoonly's Avatar
Default Re: (Syndacate)
no i have obd1 ecu which is perfect and that how it was wired, but when i put my stock ecu for emissions i get this code.
i was looking at the pins on the ecu and the ek has 3 wires on the plug 12,13,14 that are for the iac. and the gsr and type r only have one can this be part of the problem can i fix this by getting a gsr ecu or the problem has nothing to do with that??
do i have to wire it differently??
Old Aug 30, 2006 | 06:38 PM
tuyoonly's Avatar
hello,
i hope i'm not bothering you, but i would like to as you a question about a topic i put in last week?
jodyboy
10
Feb 25, 2014 06:36 PM
slowpokecivic
Feb 20, 2007 04:59 PM
pchris52
Nov 9, 2006 07:15 AM
pchris52
Nov 9, 2006 06:51 AM
-KangaRod-
Jun 22, 2005 05:45 AM
