Alas, more twin disk problems.....
Old Aug 24, 2006 | 02:27 PM
bdavis's Avatar
Default Alas, more twin disk problems..... UPDATE: IT WORKS
Update: I replaced my Master and modified a TOB and it works!! Gets a little grabby once it warms up, but it WORKS!!! Thanks for the help all!!
After the things heats up (driving for a half hour or so), the engagement becomes unbearable. it seems that after the clutch gets warmed up, you cant slip it.... at all. even to start, you have to run it up to about 4k and let the clutch out slowly and all off the sudden, BAM! it engages, no warning signs or anything, either the car stalls or peels out. i let it cool down overnight, figuring its an adjustment in the pedal or something and now its fine as its sits in my garage after it has cooled down.
im really afraid to drive my car and get stuck in traffic or something.
I bought this used, could it be a bad pp or disks?
thanks
Burke
Modified by bdavis at 9:25 AM 9/4/2006
Old Aug 24, 2006 | 03:48 PM
AutotechRD's Avatar
Default Re: Alas, more twin disk problems..... (bdavis)
sounds like a metallic disk set-up. Carbon may be the answer, although it'll cost a bunch.
Old Aug 25, 2006 | 03:26 AM
bdavis's Avatar
Default Re: Alas, more twin disk problems..... (AutotechRD)
it is a metallic. is this a common problem??
Old Aug 25, 2006 | 05:20 AM
ykracing's Avatar
not really common... and ceramic or metallic is a better move than the carbon... because the carbon CAN be temperamental in a street app.. (not always, but can be)
you may need to replace the disc and have the flywheel resurfaced..
but it could be something all together different... like a damaged bearing or PP or something... (I doubt it tho)
Old Aug 25, 2006 | 07:31 AM
bdavis's Avatar
Default Re: Alas, more twin disk problems..... (ykracing)
the flywheel was resurfaced and i ghetto resurfaced the pp and middle plate with sandpaper (its worked before on other clutches )
the clutches were a little beat up, but still had tons of meat
Old Aug 25, 2006 | 07:35 AM
ykracing's Avatar
could be trashed from heat or something.. were there lots of hot spots on the flywheel after the resurfacing?
Old Aug 25, 2006 | 12:41 PM
bdavis's Avatar
not a one
Old Aug 25, 2006 | 09:59 PM
TURBO4drTypeR's Avatar
what twin-disc are you using and did you adjust the pedal? it took me 6 months before i fried my tilton with hydro bearing kit not knowing i had to adjust my pedal luckily its only the pressure plate and i will just get it rebuilt...
Old Aug 26, 2006 | 04:56 AM
bdavis's Avatar
Default Re: Alas, more twin disk problems..... (TURBO4drTypeR)
yea i have adjusted the pedal a bunch. i didnt grind the plastic off my tob and it went last night on my way to woodward ave
oh well, im just taking it off and getting my buddies 6-puck.
this clutch would be freaking awesome if i had the right tob, but im not gonna be making "twin-disk"ish power for a while, so when i do, ill just got carbon-carbon
if anybody wants a tilton twin disk with tilton 6-lb flywheel or would want to trade it for built bottom end parts for an ls, let me know.
thanks for all you help guys
burke
Old Sep 4, 2006 | 05:26 AM
bdavis's Avatar
update: it works!!
Old Sep 4, 2006 | 06:26 PM
BlownHatch's Avatar
what fixed it ?
Old Sep 4, 2006 | 06:40 PM
Boostfed's Avatar
New User
Default Re: Alas, more twin disk problems..... (BlownHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownHatch &raquo;</TD></TR><TR><TD CLASS="quote">what fixed it ?</TD></TR></TABLE>
Look at his original post, he put it in BOLD lettering
Old Sep 5, 2006 | 07:56 PM
BlownHatch's Avatar
Default Re: Alas, more twin disk problems..... (Boostfed.com)
rrrriiiigggghhhhttttttt,i knew,i knew
Old Sep 6, 2006 | 04:44 AM
ykracing's Avatar
glad you got it figured out...
had I known it was a titon, I would have mentioned the TB modification...
oh, well, at least its fixed.
Old Sep 7, 2006 | 12:00 PM
SPOOLINmatt's Avatar
yeah you gotta grind out that plastic so the TOB can meet the pressure plate, I bet those sounds were wonderful.
cleancord
Oct 3, 2006 11:15 PM
dc2gsr96
Apr 27, 2006 06:36 AM
siregcivic
Sep 25, 2005 08:48 AM
TypeR 01 886
Jan 11, 2004 10:27 PM
wall of tvs
Jul 18, 2002 09:50 AM
