is my car crapping out on me???
ok... so lately i have been noticing that almost everytime i shut my car off for 3-5 minutes when i get back in to leave i will start it.. it will start up run for a couple of seconds and it will die.. then it will take around 2-4 minutes to get it started again... this has been going on for a couple of months now but i just ignore it until now im getting fed up with..
now the other problem i dont know if its the clutch or the clutch master cylinder... when i press on the clutch pedal around halfway down i can hear and physically feel in the pedal when depressing it a click or pop... and when i let off the pedal on the way up more near the top i hear that same pop.. if anybody can help me out that would be appreciated
Re: (siregcivic)
First problem is main relay. Common. I once traded a CRX for a Neon because of this, but I didn't know that it was common, nor that it was a easy fix back then.
Second if the clutch use(feel) it's self hasn't changed, then it's the springs in the pedal assembly binding.
Re: (diegoaccord)
hell yes its the main relay. i had the same exact problem in my 92 hatch CX. it would start then stop. then sometimes never start id come back 3 hours later she would fire right up. put new main relay in. bam problem solved.
ok thanks... im gonna get that done today.. i really dont want to be stuck anywhere.. i just noticed today... it did it and i couldnt hear the relay clicking like usual after the fuel pump primes.. actually i couldnt even hear the fuel pump...
i just put an act stage2 or hd pressure plate with street/track disc... and i took it to the track and i noticed that it was doing that but its not doing it anymore.. im gonna check the pedal assembly out for that.. thanks for the info
illusion
03-08-2003 07:06 AM
